- Feb 22, 2011
- 9,639
- 19,818
- Hymer B544 A Class
- Since 2015
I`m doing a little restoration project on my daughters Figaro car.
It involves removing a section of vinyl glued to a metal window frame which was showing some corrosion, and replacing the vinyl.
The corrosion wasn`t half as bad as I`d feared, mostly just surface corrosion.
So I scraped and sanded it, treated it with rust killer and red oxide, another sanding then a coat of Hammerite.
My problems started when I applied evostick to glue the new vinyl.
The evostick caused the Hammerite to wrinkle up
I then gave it all a fresh sanding and decided a coat of red oxide should give a suitable base, but this also caused the red oxide / Hammerite to wrinkle up, grrrr
Anyone else had this problem ?
Can anyone suggest what I can now paint it with to stabilise it before I continue with the evostick glue
TIA
TIA
