hi all my solar panel has 4.0mm leads comeing from the panel..can i put 6.0mm leads into the connections down to my victron 100/30 box or do i have to use the same size cable (4.0mm)..thanks
6mm2 would be better than 4mm2, as less voltage would be dropped over the cable run.
Can I just change terminals around as they fit into each other(still get red to red and earth to earth) thanksNormally your cabling from your panel will terminate with a MC4 connector and you will struggle to get 6mm2 into MC4 terminal crimp.
The easier way is to connect 4mm2 to the 6mm2 in a junction box.
Nothing to stop you using your 6mm2 cable other than how you are going to connect the 4mm2 to your 6mm2.
Assuming (for the sake of argument) the current being passed is 10A, then the voltage drop for 4mm2 would be around .28 volts. Switching to 6mm2 cable would reduce this to .19 volts. When you are depending on winter sun low in the sky, every little helps - but we are talking less than half of one percent benefit!What voltage drop over 3 metres on 4mm2 ?
(The figures above make some assumptions about the purity of the copper cable being used, so others might come up with slightly different results from their calculations. )
An unfounded assumption on your part and then a false argument derived from it. The calculations were based on the 20 volts typical for many panels, so not sure why you imagined it had used 12v? Also, as the voltage increases along the cable, then the voltage drop also gets greater. Otherwise I agree with you completely.....But you are not comparing apples with apples. Solar panels are pushing out 20 plus volts not the 12 volts you are assuming, so even less than the piffling voltage drop you calculate.
The voltage drop along a cable depends only on the amps, not the volts. As ericroy saidBut you are not comparing apples with apples. Solar panels are pushing out 20 plus volts not the 12 volts you are assuming, so even less than the piffling voltage drop you calculate.
