360 Vango Motor Montlena Air 330 X-Large
Wakefield, UK
coachbuild
Still learning and fitting new things to my van, I'm thinking about purchasing the Vango Montlena 330 air x-large for my van, I have a fiamma wind out awning fitted to my van (picture attached) from the bottom of the awning to ground measures 250cm, from the top of the awning to ground it's 262cm.
The vango on offer says, Designed to fit motorhomes with a height of 265cm to 280cm, the height of my van is 3.09m. My question is, is it possible to fit it on to my Fiamma awning? and does anyone know how it fit's on to it, or if it wont fit on to the awning do you think i could fit it above my Fiamma awning and make it a water tight fit and also how does it attach to the van.
Many thanks.
On the top edge of the awning there will be a kador strip
This slides into the groove on the front of the awning,it is the height of this groove from the ground when the van awning is closed that decides the height of awning you need.
You may not get a drive away but the principle is the same👍
Many thanks i will have to have a look and see if there is a rail on my awning, if not i see there are plenty on ebay
