Garratt
I'm in the process of working out a retrofit for my Rapido PVC to change the 100Ah Banner leisure battery for a 100Ah lithium. I already have a 120W solar panel that is connected to a Victron smart MPPT controller and have worked out the wiring changes needed to install the B2B (probably going with a Victron unit). However, I'm seriously considering not bothering to replace the Nordelettronica NE287 battery charger (which doesn't have a lithium profile), and simply leaving it switched off, as I'm not sure how often it would really be needed. When we are off-grid, the fridge runs on gas, and when pitched on a site, we generally plug in to shore power, so the only real loads on the leisure battery are the USB chargers, the water pump and the Truma 6E electronics and fan. The lights are all LED. At the moment, when we are on hookup, the charger is powered up, and through the Nordelettronica electronics, the charger is connected to both the leisure and starter battery (I'm guessing that there is a diode or similar to stop the habitation side taking power from the starter battery). If I disconnect the charger, then the starter battery wouldn't receive any charge, and I would have to install a trickle charger such as Sterling or Ablemail Battery Maintainer.
Does anyone have any real world experience of this? I know from reading the lithium battery threads that quite a few Funsters have changed to lithium, but the 240V charger part of it never gets discussed.
