What sort of equipment can we use on a 2000 inverter. We have two leisure batteries. Frightened we will flatten the battery quickly.
Thats about 50 amps from your batteries so for an average cook of 40 minutes would take at least 35ah so quite a chunk out of most battery banks, and if you are cooking in the evening it will be the next day before you see it going back in from solar and it could take best part of all day if the sun doesn't want to come out and play.Thankyou I do that . What I would like to do is use a Ramoska cooking pot but it is 600 watts. Is this possible unsure
It's a similar calculation. 600 watts from the inverter will draw 600/12 = 50 amps from the battery. I'm not sure how long the Ramoska would be on, but if it's 1 hour then you are taking 50 amp-hours from the batteries. That's half of the usable capacity of 100Ah. It's your call whether that's a good use of your battery power.What I would like to do is use a Ramoska cooking pot but it is 600 watts. Is this possible
I think most average unmodified motorhome systems would struggle with a Remoska and a 2000 watt inverter, but if that's what you want, a few add-ons make it perfectly feasible.Still nervous but plug in meter will be good
Pretty sure the Remoska runs continuously, we have the smaller 400w.Can't fault the calcs above 600w for an hour 50amps.
But alot of devices do not draw the stated power all the time. We had a 1200w coffee machine it only drew 1200w whilst heating up to temp, out of the 14 minutes of use to make a coffee the full power was only for about 4 minutes the rest of the time maintaining temp and pump operating was a lot lower about 250w or less.
Perhaps get a plugin meter use the remoska and it will tell you the usage, still not perfect but cheaper than buying extra batteries when not necessarily needed . We did this kept me occupied for awhile testing everything from toothbrush charger to laptop
Oh and 2 televisions one in the bedroom and one at the frontyou need lithium batteries, we don't use much gas as the solar panels keep them full, including electric toaster/ kettle, laptop, 2x ipads 2 x vaping cigs, dyson rechargeable Vac......
I am
Now wondering why they put an inverter in
Don't forget the straighteners they are equally importantSome people have very specific usages. Most commonly this is hair dryers, which apparently are such a must for some people that it is "the hair dryer works, or I'm not coming!"
