skylinersi
ok as above, long story but trying to give as much background as possible. 2017 fiat ducato pvc.
havent checked it lately, since start of feb. not run till last monday since then, but has been on hookup for a day a few times.
did have an issue with alarm not working correctly, but unplugged it and plugged it back in, alrm worked fine.......
last monday van went in for low mileage first service, just oil and filter.
noticed starter battery on control panel was low, put on hook up, up to 12.7 v, but dropped to 12v ish over night once hook up taken off. no consumers left on, only alarm and immob,
alternator seems fine
its due its hab check, so this will be looked at , they will do a check to see if its a drain somewhere?
so, is the battery duff?
is it the alarm immob?, although they draw so little?
could something have happened during the service or is it just coincidence?
is it because we havent used the van, or kept it hooked up?
or is it just sods law and the battery has expired anyway.....
should a cab battery only last 2 years??
the battery when i have checked it on the panel has been sat at 12.4 or 12.7 so never been an issue....till the last week or so
so, bit peeved tbh
dealer did say that as the van is still within its base 2 yr warranty fiat would cover and replace the battery????????
all help welcome
so, bit peeved tbh
all help welcome
