2016 Frankia I680 toilet 12volt
Manic
Uk
Frankia I680
Does anybody know where Frankia would take the 12 volt power from for the toilet, mines not flushing,no power to it.
I thought they usually had a fuse in the back but can’t find that either.
Cheers
Fuse for ours was tucked up top left in the cassette compartment.
Yes where I thought, also scene on YouTube a fuse near level sensor,under a cover on the c250 but not on mine.😒
Don't know what your flush button set up is but the pcb used to fall off the back of ours when someone used to push it to hard 😠
But I have no 12volt
Have you checked the fuses in the distribution unit, common for there to be no fuse at the toilet end when flushing from the tank.
Yes I’ve checked fuses on the EBL but I will try again
Cheers
Yes checked with meter and checked additional fuses
A dummy has sorted it now. When I had the reverse polarity on the Tv points when refitting fuses I must of missed the wrong fuse, I know there was a gap but i must of left the wrong fuse out, I think it should have been the aes fuse missing 😒
Toilet now flushes and the lounge lights work.
Off the France Wednesday 😊
