2014 Boxer 130 HDI .. temperature sensor not working / missing ... is the DPF regen affected? (1 Viewer)
Sep 17, 2020
946
3,151
Totton
Bailey Autograph 745
Since Sept 2020.
We've just picked up a new-to-us Bailey Autograph on a Boxer base. The temperature gauge on the dash just shows three dots, and there's a hole under the offside mirror where I think there ought to be a temperature sensor after having done a lot of 'research', i.e. an hour on Google. A recurring theme is that the absence of the sensor, usually because a non-original offside mirror has been fitted after damage to the original, can cause the DPF regeneration to fail.
I've spoken to the dealer and they have arranged for the van to go to their service agent, but they are telling me the DPF is not affected. I've seen a video on this forum that suggested the opposite, so I'm looking for some credible proof either way.
Can anyone assist?
Feb 22, 2016
3,636
10,930
York
Bailey 620 Approach
I don’t know if this helps but after a flat cab battery the temperature gauge stopped displaying. I disconnected the cab battery for 30 mins and when I reconnected it displayed and worked correctly afterwards.
Dec 6, 2011
11,640
25,592
South Wales
Coach built Adria
our Ducato is not fitted with outside temp sensor and has a dpf. i have seen the video in question but i must admit to being not completely convinced that it has a significant effect on the regen process.
it certainly does not in our case.
May 7, 2016
7,310
11,819
West Sussex
Malibu Van 640 LE K
Since 2003
I have certainly heard that on some vehicles the outside temperature is needed for the regen. I can believe that external temperature has a bearing on the process.
Jan 27, 2018
2,686
2,136
Northampton
Rapido & Bongone
I agree, checking Multiecuscan all x250,x290 2,3 have the body ecu ability to read a mirror temp sensor weather fitted or not
Trevor Wbm
Sep 17, 2020
946
3,151
Totton
Since Sept 2020.
Thanks all. I'll see what their service garage says. Our local Peugeot commercial garage offers a diagnostic service and free safety check, so may use them if I'm still not convinced.
Meanwhile, very happy with the new(er) van, already booked by Grandson 2 for Go-Karting support duties.
Head scratcher
4
5
Peugeot Boxer 2016
Can anyone assist?
Our 2016 Boxer has same issue but we have a temp sensor in the mirror but it reads around 40c when it’s around 8 or 9c
We’ve had the van go into limp mode 4 times in 18 months all on long runs with engine revs kept fairly high as always conscious of it now but only stumbled upon the temp sensor problem recently and the effect it can have on DPF Regens hence limp mode and AA assistance !!!
I’m going to try and replace the sensor myself by cutting the in place sensor wire from the plug and attaching and soldering and heat shrinking the new one in place but I’ve actually plumped for an NTC thermistor rather than the original one as these appear to be much more reliable so if all goes to plan I won’t need to replace the whole wing mirror unit and save a lot of money 🤞
17,655
43,501
the sensor does contain an NTC thermistor, but be aware that different types have different temperature gradients. Put simply the resistance varies with temperature and different models give different outputs
Apr 20, 2022
656
1,221
Brighouse, UK
Autoquest 155 2016
Since 2020
They are less than £30 from Fiat for genuine one. Part number is here on forum some where. I posted it but cant get to it in my records at the moment.
edit here it is
For any one who needs a sensor the fiat part number is A0001375410080 and I paid £27.18 inc vat for mine in Jan 2022. Northern Commercials Brighouse
Jan 27, 2018
2,686
2,136
Northampton
Rapido & Bongone
Since my original post here i investigated further and posted elsewhere a full post.
Ducatos pre 2020 do not use the mirror sensor for regen. The mirror sensor is read by the BCM or BSI (peugeot terminology)low speed canbus. The ducato has ambient temp sensor AIF in the MAF read by hi speed can in engine ecu. Different engine ecus are used in Fiat P&C so may even be a different MAF. The P&C adblue engine do use the mirror sensor. The ducato adblu engines i'm not sure (why use a slow speed for engine control when have been using high speed and MAF for years), but, there is a separate Ducato adblue module that also has a tank temperature sensor and measures temp at the injector. Hope this doesnt confuse
