1993 hymer...fiat Ducato rear brake shoes...how do I go about buying them ? And what do I look for
paible
Orkney
Erinlucy123
Hymer A class 1993
I’ve luckily purchased a lovely Hymer, though she needs work for MOT. Trying to find parts that I need but just to much options out there...total beginner ....thanks in advance
I wouldn’t know but someone will be along to help , this will also bump it to the top
Think you would need to give them the model name / number
welcome to fun
Whats Up Hello GIF by Make it Move
Just ring around for quotes from garages with good reputations that have the capacity to handle the size and weight of your camper.
Prices of the brake parts differ for different brands & quality.
Ask the garage to change the brake fluid at the same time as it's hygroscopic and needs changing at regular intervals.
Ask the garage to replace your engine coolant, engine oil, oil filter, air filter at the same time unless it's been done recently.
Don’t think he is looking for a garage BUT wants to identify the parts he needs to order ( unless I read it wrong )
getting parts in the Orkney isles won’t be easy
fond memories of orkney & beach races 👍
I got my pads, discs and fitting kits from these.
Good website that lists all possible models, but then gives you the info on wheel size and calliper manufacturer, so was able to workout exactly what I required.
:welco:
Even if you van has an Al-Ko chassis the brake parts will be the same as the base vehicle. So if its built on a Fiat Ducato the brake parts will be Fiat Ducato etc. The handbrake cable will probably be different but there are a few companies that make them to order.
