12v tv how do I connect without electricity
peugeot boxer
12v tv in motor home how do I connect without
Electric
If it is a 12v TV just plug into a 12v socket, same as a dashboard cig lighter socket.
You will need a 12v lead with suitable TV plug and remove the mains lead TV plug
Eerrrrr every tv needs electricity !
Presume you mean without 240 volt.
Answers above should do.
Did it not come with the 12v lead.
It should have fag lighter plug on one end and maybe the 5.5mm barrel connector for the tv end.
Electric
Depends what you want to use the TV for? If you want to use it as a TV then you NEED electricity .... As has been patiently pointed out by others, the electric could be provided by a 12v supply of electricity, usually through an additional battery but could also be connected via a power bank of some sort (lots on you tube to look at). Don't use the vehicle battery as it may mean you can't drive away ....
Of course if you don't want to use it as a TV then you don't need to connect it to anything .....
If you're not sure how to use a TV in a motorhome I would advise spending a few nights at home in the driveway/garden because there are a lot more important things to understand about how things connect and work in a motorhome. There are quite a few you tube videos showing how to set up on site - even caravan set ups would be helpful to watch if you don't yet understand how to set up on site.
