12v Sockets how do they come apart?
zac
Basingstoke
Rapido A CLass 10000
since 2013
Anyone know how the bottom socket of the pic shown comes off, the hella shaped one? I want to split off another connection to the other side of the bed but need to get to the wiring. Can't seem to see how I can get to the back of this as it's all enclosed. Read that on some the front pops off but this seems pretty tight if it does. I never use either of these sockets
The outer trim pops off exposing a couple of screws
yes, use a plain table knife to avoid damage.
  • Informative
Reactions: zac
A slim flat blade between the light and dark bits and lever off.
The light bit stays in place, the bezel pops off.
Remember, it's a 10a fuse so the combined load of 5he two sockets must be 10a maximum or less.
  • Informative
Reactions: zac
Thanks will give it a go now I know it definitely pops off. Didn't want to damage it.
Treat yourself to one of the kits to get things like this off, they're available on Ebay for a couple of quid.
Got lots of sacrificial plastic items to avoid damaging your treasured surfaces.
I even keep on in the car for the bumper towing eye cover (anyone tried getting one of those off?).
:giggle: You have more patience than me, ;) if it got to the point we needed to use the towing eye and then it wanted a turn of being a pain in the @r$e, it would feel the sharp end of our can opener on it's derier.
Mike.
I've got some at home but as always I never have what I need when I decide to do it lol
You may find a recess on one of the sides of the darker outer casing, where the casing sits against the veneer. If so, then this is where you should be able to insert a blunt knife or fine screwdriver to pull the casing away.
  • Informative
Reactions: zac
Also worth knowing that towing eyes are left hand threaded. Not sure why they are but very frustrating when you don't know!o_O
Ours is conventional right hand thread on a 2011 Ducato
So worth trying both ways if having difficulty!
The reason I believe is due to the way rope and cable is twisted and having a tendency when under load to unscrew a right hand thread.
