X250 stiff gear seletion (1 Viewer)
micky drip
191
121
mid wales
c class
5 years
My Ducato has done 15k, gear selection is getting increasingly difficult, especially 1st and reverse. Is there anything I can do before taking it to a proffessional?
Chris
21,056
279,063
10 years
Put the clutch in?::bigsmile:
Seriously though, I have a few problems as well especially with 4th and 6th.
43,337
49,538
selector linkages and cables may need lubricating.
not sure but i think the links are behind the dash shroud
longdog
Banned
Apr 16, 2013
255
287
Excuse my ignorance, but is this the Ducato Max chassis?
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
you cannot beat a bit of lubrication when things get stiff:RollEyes:
Dec 30, 2008
1,106
2,126
Cheshire
since Dec 2008 after 10 years caravanning
Pull the gaiter off from around the gear stick, this will expose the top gear linkages, you can lubricate them and hope it helps,
Eric
micky drip
micky drip
191
121
mid wales
c class
5 years
Thanks eric I`ll get the WD 40 out.
Dec 6, 2011
11,600
25,453
South Wales
Coach built Adria
carefull with the WD 40 it makes some plastics "swell" and i believe the parts under the gaiter are plastic....
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
WD40 is not intended as a lubricant. It is more likely to dissolve any remaining lubricant and make things much worse (but better for a day or two, so it looks like it has fixed it).
aba
2,775
1,112
yorkshire
dec 2009
You could check on top of the gearbox if something has dropped onto the linkages,
We had a motorhome that wouldn't select reverse at work and it turned out to be the heater intake drain pipe had somehow got caught up in the linkage jamming it.
Dec 6, 2011
11,600
25,453
South Wales
Coach built Adria
i am sure there are a few types but i use this on plastic gears.
i learnt the hard way with WD40, sprayed it into locks on a caravan to keep them smooth, the main habitation lock seized through swelling of the plastic due to a reaction with the WD40. this was confirmed when i purchased the replacement.:Doh:
not all plastics are affected but on the basis of its better to be sure than sorry!:thumb:
