X250 stiff gear seletion
Discussion in 'Tech/Mech General' started by micky drip, Apr 26, 2014.
  1. micky drip
    micky drip Read Only Funster
    Jul 4, 2012
    190
    121
    mid wales
    My Ducato has done 15k, gear selection is getting increasingly difficult, especially 1st and reverse. Is there anything I can do before taking it to a proffessional?
  2. Chris
    Chris Funster Life Member
    May 5, 2010
    16,725
    36,812
    kent
    Put the clutch in?:BigGrin:
    Seriously though, I have a few problems as well especially with 4th and 6th.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,102
    17,771
    YO11 2BD
    selector linkages and cables may need lubricating.
    not sure but i think the links are behind the dash shroud
  4. longdog
    longdog
    Apr 16, 2013
    233
    232
    Swansea, South Wales
    Excuse my ignorance, but is this the Ducato Max chassis?
  5. pappajohn
    Aug 26, 2007
    30,102
    17,771
    YO11 2BD
    wheelbase and weigh i believe
  6. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    you cannot beat a bit of lubrication when things get stiff:RollEyes:
  7. micky drip
    Jul 4, 2012
    190
    121
    mid wales
    I wish !!
    • Like it Like it x 2
  8. gloworm
    gloworm Funster
    Dec 30, 2008
    917
    1,731
    Cheshire
    Pull the gaiter off from around the gear stick, this will expose the top gear linkages, you can lubricate them and hope it helps,
    Eric
    • Like it Like it x 3
  9. micky drip
    Jul 4, 2012
    190
    121
    mid wales
    Thanks eric I`ll get the WD 40 out.
  10. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    carefull with the WD 40 it makes some plastics "swell" and i believe the parts under the gaiter are plastic....
  11. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    WD40 is not intended as a lubricant. It is more likely to dissolve any remaining lubricant and make things much worse (but better for a day or two, so it looks like it has fixed it).
    • Like it Like it x 1
  12. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    You could check on top of the gearbox if something has dropped onto the linkages,
    We had a motorhome that wouldn't select reverse at work and it turned out to be the heater intake drain pipe had somehow got caught up in the linkage jamming it.
  13. DeuceBG
    DeuceBG Funster
    Oct 28, 2013
    486
    432
    Lincoln
  14. micky drip
    Jul 4, 2012
    190
    121
    mid wales
    I never thought of that. Any suggestions wot to use?
  15. Phill D
    Dec 6, 2011
    4,414
    4,633
    South Wales
    i am sure there are a few types but i use this on plastic gears.
    http://www.ebay.co.uk/itm/SERVO-Gea...ars-last-/120847505256?_trksid=p2054897.l4275
    i learnt the hard way with WD40, sprayed it into locks on a caravan to keep them smooth, the main habitation lock seized through swelling of the plastic due to a reaction with the WD40. this was confirmed when i purchased the replacement.:Doh:
    not all plastics are affected but on the basis of its better to be sure than sorry!:thumb:
