Why are things so awkward? (1 Viewer)
Touchwood
772
733
NE England
Compass Avantgarde 140
5 years and learning
Anyone else had this, or a similar problem?
There are shelves in the top lockers of my MH, but they are pretty flimsy and I've planned for a while to replace them with thicker ones. Today I decided to remove the old shelves to use as templates for the replacements. Guess what - they won't come out of the locker unless I bend them - and of course if the new ones are thicker they won't bend and therefore I wouldn't be able to get them in! :Angry: The only idea I have at the moment is to make the new ones in two halves with some sort of cunning joint, but I'm not sure how to do this as yet.
Any ideas?
Chris
21,056
279,072
10 years
I don't have a practical bone in my body, but could you not join the two halves using a door hinge. Close the "door" to get it in and then open it to fix in as a shelf.
Feel free to ignore me::bigsmile:
Touchwood
Touchwood
772
733
NE England
why not just reinforce the existing ones by fixing an additional thickness to them/:Eeek:
Now that's a damn fine idea - needn't be full size, just a reinforcing strip. I'm sure I would have thought of that eventually. :Smile:
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Why bother reinforcing them or replacing them with heavier shelves though? High level lockers are unsuited to carrying heavy loads and should only be used for carrying light stuff therefore the "flimsy" original shelves will be fine. Replacing them with heavier duty shelves will only achieve two things, both of which are less than ideal:
1, the shelves will be heavier than original thereby reducing your actual payload.
2, the heavier duty shelves will only tempt you to put heavier goods on them and as they are in high level lockers this is not a good place for heavier items.
D.
camocam1
1,112
788
Elgin,Moray,Scotland
bailey approach 760 se
Have to agree with Dave on that high level lockers are it good for storing anything heavy which you may be tempted to do but if you do wish to proceed what I did when I added extra lightweight shelfs was to bore several holes either side for the plastic shelf supports from B&Q etc then put the shelf in at an angle straightened it up the put the supports in the holes
I an now adjust shelf to different sizes depending on what I want to store in the locker
Touchwood
Touchwood
772
733
NE England
D.
I fully take your point, Dave, but when I say flimsy I mean the thickness is barely more than hardboard, they bend with very little load. I did plan to replace them with 25 mm ply, hardly a massive increase in weight, and I'm well aware of the dangers of storing heavy stuff in high lockers, especially since the locker doors don't have particularly secure latches.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
And if you fix one strip across the top of the front edge of a shelf it would help to stop things sliding off.
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
That sounds like an enormous (25 times) increase in weight if the originals are say 1mm, or did you mean 2.5mm? :Doh:
Jan 28, 2008
10,121
18,387
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
just fixing an upstand to the front edge will stiffen the shelves unless the span is massive 25mm ply is definatly over kill
Touchwood
Touchwood
772
733
NE England
opp5- yes, I meant 5 or 6 mm (one quarter inch in old money) Senior moment :roflmto:
