What Kind Of Internal Lights Are These? (2 Viewers)
TheWM
445
450
London
Rapido 9010df
Newbie, but over 10 years in a campervan
I have no idea whether they are led or halogen - never seen these before. Anyone come across them? It reads max 10w G4 - but being a German owned can I would have thought they would have changed to led but I can't tell.
jumar
3,780
11,637
Spain
Hymer Tramp
Since 1994
LED I have these throughout my van. Great efficient lighting.
4,924
11,290
Flintshire
Low profile
since 2010
10 w G4 refers to the Lamp holder, G4 is the type of bulb fitting and 10W would be the max wattage for that bulb holder, the 'bulb' fitted in the photo is a LED and I bet you it's no more than 5watt.
TheWM
TheWM
445
450
London
Rapido 9010df
Cool. Thanks - saves me having to replace them.
43,348
49,550
If you ever need to remove/replace them its very easy.
The part of the lamp with the numbers embossed is the holder.
the led disc has two thin wire pins on the edge which push into the holder.
to remove, carefully lever down the opposite edge just enough to get hold of the disc then pull away from the holder...not downwards or you break off the pins.
or, using finger nails or similar push the disc away from the holder untill it falls out.
11,732
13,711
Sorry to highjack the thread a bit, but I am looking to get some recessed light holders similar to the ones in the photo, to replace the ones I have at the moment, which are an absolute pig to take apart to replace the bulbs. Anybody know where I can get them from please. Don't have to be identical, but do need to be stainless steel or chrome.
967
3,361
Nice slim ones, various finishes ..... As always... Ebay-our friend !
Gandhi
170
303
Near Glossop
bessacar E496
5 years
LED's. By far the best choice . Cold to the touch and your battery will last for ever with them. I've replaced all my halogens with LED's and the difference in battery life is phenomenal.
11,732
13,711
I have done the same. The trouble is they were cheap LEDs from China and some are flickering and failing, so need to replace them and the existing downlighters are an absolute pig to open up to get at the bulb. So thinking of replacing them.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I replaced all my halogens and tubes with them so the MH has no trouble running off just the solar panel. Not cheap, but a good long-term investment. I had to modify some light fittings and replace others.
They're great until one of the elements develops a flicker - carry a few extras and don't be fooled into thinking they'll last forever.
ojibway
531
305
Eastbourne
since 2005
I've had LEDs since 2006 - early ones didn't cope with fluctuating voltage but new one are great. I have even replaced some bulbs with strips of LEDs!
