What Kind Of Internal Lights Are These?
Discussion in 'The Beginner' started by TheWM, May 16, 2015.
  1. TheWM
    TheWM Read Only Funster
    Feb 24, 2015
    445
    450
    London
    I have no idea whether they are led or halogen - never seen these before. Anyone come across them? It reads max 10w G4 - but being a German owned can I would have thought they would have changed to led but I can't tell.
  2. WAG2CRU
    WAG2CRU Read Only Funster
    May 31, 2012
    378
    496
    Argyll
    they are led.
  3. jumar
    jumar Funster
    Nov 6, 2012
    869
    1,196
    Spain
    LED I have these throughout my van. Great efficient lighting.
  4. Gooney
    Gooney Funster
    Jun 2, 2010
    4,766
    7,853
    Flintshire
    10 w G4 refers to the Lamp holder, G4 is the type of bulb fitting and 10W would be the max wattage for that bulb holder, the 'bulb' fitted in the photo is a LED and I bet you it's no more than 5watt.
  5. TheWM
    Feb 24, 2015
    445
    450
    London
    Cool. Thanks - saves me having to replace them.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,579
    YO11 2BD
    If you ever need to remove/replace them its very easy.
    The part of the lamp with the numbers embossed is the holder.
    the led disc has two thin wire pins on the edge which push into the holder.
    to remove, carefully lever down the opposite edge just enough to get hold of the disc then pull away from the holder...not downwards or you break off the pins.
    or, using finger nails or similar push the disc away from the holder untill it falls out.
  7. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,567
    2,570
    Tunbridge Wells
    Sorry to highjack the thread a bit, but I am looking to get some recessed light holders similar to the ones in the photo, to replace the ones I have at the moment, which are an absolute pig to take apart to replace the bulbs. Anybody know where I can get them from please. Don't have to be identical, but do need to be stainless steel or chrome.
  8. Jonkil
    Jonkil
    Dec 27, 2014
    963
    3,174
    Ireland / London
    Nice slim ones, various finishes ..... As always... Ebay-our friend !
    http://www.ebay.co.uk/itm/Metal-Rou...t=LH_DefaultDomain_3&var=&hash=item2ed2a6eb30
    • Like Like x 1
  9. Gandhi
    Gandhi
    Sep 9, 2014
    170
    303
    Near Glossop
    LED's. By far the best choice . Cold to the touch and your battery will last for ever with them. I've replaced all my halogens with LED's and the difference in battery life is phenomenal.
    • Like Like x 1
  10. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,567
    2,570
    Tunbridge Wells
    I have done the same. The trouble is they were cheap LEDs from China and some are flickering and failing, so need to replace them and the existing downlighters are an absolute pig to open up to get at the bulb. So thinking of replacing them.
  11. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,719
    8,809
    NW England
    I replaced all my halogens and tubes with them so the MH has no trouble running off just the solar panel. Not cheap, but a good long-term investment. I had to modify some light fittings and replace others.
    They're great until one of the elements develops a flicker - carry a few extras and don't be fooled into thinking they'll last forever.
    • Like Like x 1
  12. Gandhi
    Gandhi
    Sep 9, 2014
    170
    303
    Near Glossop
  13. Jonkil
    Jonkil
    Dec 27, 2014
    963
    3,174
    Ireland / London
    Yes,
    Bulbs replaceable with G4 LED's.
  14. Gandhi
    Gandhi
    Sep 9, 2014
    170
    303
    Near Glossop
    Oh right.
  15. ojibway
    ojibway Funster
    Jul 17, 2012
    530
    298
    Eastbourne
    I've had LEDs since 2006 - early ones didn't cope with fluctuating voltage but new one are great. I have even replaced some bulbs with strips of LEDs!
