Water pump problem (3 Viewers)
kickstart
448
114
south yorkshire, Benidorm
low profile
4 years
One minute taps were working, next day nothing, not a sound or anything. she is ten year old so I thought new water pump. went to Camper UK in Lincoln today gave them my Burster model and serial number and they said this is the one IMG_1684.JPG
can anyone help ?
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
I'm no expert but check your water tank pump may have come off and be lying at bottom of tank:eek:
43,337
49,538
It appears your pump has already been replace....but with a different pump.
Though I have to say....I've never seen a pump like that before.
Stick to the one recommended.
SandraL
1,373
985
Somerset
Hymer b694sl
Could it be that 2nd pic is of the level sensor? Can you unscrew access hatch and put hand inside to see what is under that top, if a level sensor as we have then there will be 3 or 4 stainless steel rods of different lengths.
Alternatively I could well be talking rubbish.......
SandraL
1,373
985
Somerset
Hymer b694sl
Re last picture, Could cable be for power to pump and hose the water outlet? Otherwise a vent/ overflow. Is there not a screw cap for cleaning you can get your hand inside the tank?
Jul 23, 2012
80
82
Kingswinford & 86230
Burstner Elegance 890
That the same as my Burstner Elegance, the round black pic is the level sensor, the pump is inside the tank at the other end of that hose pipe.
Should be an acess 'plug' on the top of the tank big enough (just) to get your hand inside
kickstart
kickstart
448
114
low profile
4 years
Thanks so much for your help Sandra and Timotei, think it must be the second picture, will attempt it tomorrow.
Apr 27, 2016
6,876
8,002
Manchester
A class Hymer
Since the 80s
Follow the wire to a connector, and see if you get power there when you turn a tap on.
A sudden failure like that is just as likely to be an electrical problem as a failed pump.
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
Have you got power at the pump connection?
Enword
1,900
7,999
Devon
Coach Built
Do you have a multi meter? test at the pump plug,
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Trace the cable on your tank back to the terminal block, put a multimeter across the terminals then get someone to open a tap and see if you read 12 volts.
Dec 12, 2010
5,415
21,607
Cumbria
how would I find out if I have ?
Ideally you would use a multi meter, do you have one ? Failing that you can rig up a 12 volt bulb and two lengths of wire connected to where the pump picks up it's power supply from, but first check the pump fuse is ok and if you have the Reich controller fitted, check you have selected the water pump ON and not to OFF or AUTO.
JeanLuc
3,304
2,199
Warwickshire
Just a thought, you said in the first post 'one minute taps were working'. Did you test both sink and bathroom taps and neither activated the pump?
kickstart
kickstart
448
114
low profile
4 years
yes checked all taps, not got a multi meter but will get one tomorrow, checked fuse and Reich controller is turned on,
