Water heater dump valve (3 Viewers)
23,836
72,558
Heard a drip under the van the other day..
Turned out to be the dump valve leaking by..
Tried a quick reseat ( opened and closed the thing several times ) but to know avail.
Anyone know of a fix or replacement ?
Damned if I am going to pay £79 for a small bit of plastic that for any application apart from motorhome related would proly be about £7 or £8 !!
DanielFord
3,020
3,086
And failing that, they are simply a valve, there must be something one could improvise with at a plumbers merchants? As long as the hoses fit, shouldn't be too difficult to replace.
23,836
72,558
What type of valve is it? manual automatic?
Thats the little bugger !!
I spent an hour yesterday looking for one and could not find it.. Cheers Andy.. Will be getting one on order !
Thanks to PJ, Dan and Jim too for your inputs.. all possibles and all good stuff, but for £6 I will just replace the thing !!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I would strip and clean it first as Jim suggested. That one is on AUCTION but BIN are around £28
EDIT
Looking at the picture it looks like the metal head is crimped on so not a straight forward service
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
My auto dump valve is a pain it wants to drop the water whenever the temperature is lowish not 4 degrees but just cooler than 10 and it will not reseal until I put a heater on it to warm it right up. If I leave the pump on it will drop the lot. A clothes peg has been brought into action to hold it up.
ebo
Nov 9, 2009
98
105
A class Carado i449
Just replaced the very same valve for a friend of mine, unfortunately they are unserviceable as techno said they're about £28.
2,356
10,243
No need to strip the valve to clean it.. simply soaking overnight in a hot water/white vinegar solution will remove the limescale..
if that doesn't work.. then perhaps replacing is the only option..
but before I forked out 30 quid I would still strip and see if it could be repaired.. nothing ventured .. etc
DanielFord
3,020
3,086
I'm going to order one of them also. Mine works perfectly at the moment, but in a year or so when mine fails, I know I will have forgotten about this thread! :D
Carry on like that and in a year or so you be done for being overweight.
jaykay
199
184
North Lincolnshire
Rapido 997M Auto
Virtually none ! :)
Mine is the same (auto) and I also use a peg to keep it closed.
23,836
72,558
Hey Jaws where's your Dash Cam thread Gone??
I dunno ! Dropped out of site by now I should think mate..
Will take a look as doing another order when we get home though
Jun 30, 2010
7,925
27,238
1992 VW Auto sleeper Mono
Since 2005 this time
I've got an electric Automatic dump valve going spare, surplus to requirements.
Swap you for a BBQ gas point.
23,836
72,558
Bloody ebay nutters.. That thing ended at £28 inc post.. about the same as a lot of places sell them new anyway !
Depends on what type of gas point you want mate ?
I do have a spare.. It is a fly lead type that I used to have t'ed in to the low pressure side of the regulator
Can supply all pipe and T piece if any good ?
Jun 30, 2010
7,925
27,238
Got a picture? Not quite sure what you mean.
I would like the one that fits into the Bodywork, so that you don't have to open the door. Can I use the one you have like that?
etap
256
228
Somerset
Chausson Flash 610
3 years
Hi Techno 100 and Jaws,
Looking at the valve on eBay that you showed, it looks like the one we have on our new Chausson 610 but I thought it was the frost safety valve, if it is not then we don't have a frost safety valve on our MH, can you or anyone else inform me whether Chausson don't now fit them as standard? Be pleased with the answer.
Etap
jaykay
199
184
North Lincolnshire
Rapido 997M Auto
Virtually none ! :)
Ours is a frost valve with the red plunger, and it needs a peg to keep it up....:LOL:
11,933
9,097
IF It`s 15mm Hard plastic? then look here:-
http://www.screwfix.com/p/jg-speedfit-15esotp-emergency-shut-off-tap-15mm/13133
I am assuming it IS only a drain down valve so anything like this would do and at £4-99 a damn sight cheaper that a "pukka" job!!!!
Pete
Hi Pete the link shows a 15 mm one -almost all caravan M/H stuff is 12 mm and is almost only available through M/H suppliers / outlets --if anyone needs or wants to use 15 mm piping I have a load of 15 to 12 reducers (y)
We find using 15 mm pipes and reducing to 12 mm for pumps etc allows you to use proper taps instead of the expensive M/H versions and cheaper 15mm push fit s for Joints etc :)
terry
