Water heater dump valve
Discussion in 'Motorhome Chat' started by Jaws, Mar 15, 2015.
  1. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    Heard a drip under the van the other day..
    Turned out to be the dump valve leaking by..
    Tried a quick reseat ( opened and closed the thing several times ) but to know avail.
    Anyone know of a fix or replacement ?
    Damned if I am going to pay £79 for a small bit of plastic that for any application apart from motorhome related would proly be about £7 or £8 !!
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,703
    17,323
    YO11 2BD
    Could try backflushing john.
    Stick a hose on the outlet and open the dump valve.
    Back flow may dislodge any grit on the valve seat.
    • Like Like x 2
  3. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,315
    2,607
    Surrey
    And failing that, they are simply a valve, there must be something one could improvise with at a plumbers merchants? As long as the hoses fit, shouldn't be too difficult to replace.
    • Like Like x 1
  4. scotjimland
    Jul 25, 2007
    28,934
    25,589
    Remove and clean.. probably scale on the valve seat ... soak in warm water and white vinegar
    • Like Like x 3
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
  6. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    Thats the little bugger !!
    I spent an hour yesterday looking for one and could not find it.. Cheers Andy.. Will be getting one on order !
    Thanks to PJ, Dan and Jim too for your inputs.. all possibles and all good stuff, but for £6 I will just replace the thing !!
  7. Techno
    Jul 28, 2010
    14,107
    14,921
  8. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    1,988
    1,432
    Dover
    My auto dump valve is a pain it wants to drop the water whenever the temperature is lowish not 4 degrees but just cooler than 10 and it will not reseal until I put a heater on it to warm it right up. If I leave the pump on it will drop the lot. A clothes peg has been brought into action to hold it up.
    • Like Like x 1
  9. ebo
    ebo Read Only Funster
    Nov 9, 2009
    65
    56
    Essex
    Just replaced the very same valve for a friend of mine, unfortunately they are unserviceable as techno said they're about £28.
  10. scotjimland
    Jul 25, 2007
    28,934
    25,589
    No need to strip the valve to clean it.. simply soaking overnight in a hot water/white vinegar solution will remove the limescale..
    if that doesn't work.. then perhaps replacing is the only option..
    but before I forked out 30 quid I would still strip and see if it could be repaired.. nothing ventured .. etc
    • Like Like x 2
  11. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,315
    2,607
    Surrey
    I'm going to order one of them also. Mine works perfectly at the moment, but in a year or so when mine fails, I know I will have forgotten about this thread! :D
  12. hilldweller
    Dec 5, 2008
    26,909
    25,760
    Macclesfield
    Carry on like that and in a year or so you be done for being overweight.
  13. jaykay
    jaykay Read Only Funster
    Aug 19, 2011
    199
    183
    North Lincolnshire
    Mine is the same (auto) and I also use a peg to keep it closed.
    • Like Like x 1
  14. Frentchy
    Frentchy
    Oct 2, 2013
    596
    2,303
    Bordeaux France
    Hey Jaws where's your Dash Cam thread Gone??
  15. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    I dunno ! Dropped out of site by now I should think mate..
    Will take a look as doing another order when we get home though
    • Like Like x 1
  16. rangitira
    rangitira Funster
    Jun 30, 2010
    6,322
    12,820
    Cornwall
    I've got an electric Automatic dump valve going spare, surplus to requirements.
    Swap you for a BBQ gas point.
  17. Jaws
    Sep 26, 2008
    18,584
    22,497
    Narrfoook
    Bloody ebay nutters.. That thing ended at £28 inc post.. about the same as a lot of places sell them new anyway !
    Depends on what type of gas point you want mate ?
    I do have a spare.. It is a fly lead type that I used to have t'ed in to the low pressure side of the regulator
    Can supply all pipe and T piece if any good ?
    • Like Like x 1
  18. rangitira
    rangitira Funster
    Jun 30, 2010
    6,322
    12,820
    Cornwall
    Got a picture? Not quite sure what you mean.
    I would like the one that fits into the Bodywork, so that you don't have to open the door. Can I use the one you have like that?
  19. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    Hi Techno 100 and Jaws,
    Looking at the valve on eBay that you showed, it looks like the one we have on our new Chausson 610 but I thought it was the frost safety valve, if it is not then we don't have a frost safety valve on our MH, can you or anyone else inform me whether Chausson don't now fit them as standard? Be pleased with the answer.
    Etap
  20. PeteH
    PeteH Funster
    Nov 22, 2007
    1,982
    2,430
    East Yorkshire
