Very light gas smell in gas locker. Is it normal? (1 Viewer)
Nov 3, 2016
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
i was in my gas locker again yesterday to turn the gas back on after the Truma repair (dealers switched it off after working on it)
And again I notice a very slight gas smell inside the locker. It's been like that since I bought it and having had its Habitation checks done and X2 checks on the heater without anyone at the dealership saying it's not normal (forgot to ask)
Is it normal to have a slight smell of gas? It's well vented to the underside of the van and zero smell inside the home. Just keep thinking surely with all hoses tightened up it should be 100% odour free?
Dec 24, 2014
9,294
47,925
Hurstpierpoint. Mid Sussex.
Compass Navigator
In spite of regular intensive leak checks there was always a whiff in the locker when I had Calor exchange cylinders and I put it down to gas draining from the pipes when I disconnected the pigtails to remove the cylinders. I very rarely ran the cylinders to completely empty before exchanging them.
No smell at all from my Refillable system with Gaslow s/steel pipes.
TerryL
6,205
8,215
North East
Low Profile
Always seem to have a slight smell lingering for a day or two after refilling our Gaslows. Strangely, though, it doesn't set off the leak detector pen I use to check connections - which I do calibrate periodically against a known source.
Edit - we've got all stainless steel hoses.
kevenh
3,319
11,801
Thatcham
Compass C-Class
I'm a Progressing Newbie
My 2p
The gas is odourless
So a smelly thing is added in with the gas.
Overtime that odour permeates through rubber hoses.
Hmm! Anyone with a new MH or hose got the odour? šŸ¤” :rofl:
AXO66
762
4,715
Pembrokeshire
Chasson 510
Yep same here.
slight gas smell
but when i had a poor calour gas cylinder that did leak, it was much, much, worse.
very reassuring to hear many others have a slight smell. Makes me think it is ā€œnormalā€œ
1,442
1,587
North Ayrshire
Adria Matrix 670SC
Same with mine, had it at the dealers for a check and pressure test and nothing was found. Glad to hear itā€™s not just mine.
55
53
Scotland Central
A Class Pilote
Since 2014
the bottle locker should have holes in the floor to permit the gas to vent as it is heavier than air.
however a already indicated a check with gas leak solution and a wee brush will tell if there are any issues.
