Very light gas smell in gas locker. Is it normal? (1 Viewer)
Nov 3, 2016
881
1,679
Derbyshire, UK
Bailey Autograph
Since 2016
i was in my gas locker again yesterday to turn the gas back on after the Truma repair (dealers switched it off after working on it)
And again I notice a very slight gas smell inside the locker. It's been like that since I bought it and having had its Habitation checks done and X2 checks on the heater without anyone at the dealership saying it's not normal (forgot to ask)
Is it normal to have a slight smell of gas? It's well vented to the underside of the van and zero smell inside the home. Just keep thinking surely with all hoses tightened up it should be 100% odour free?
Howard H
4,827
4,786
West Lancashire
Benimar mileo 294
Like you I have a slight smell of gas in the gas locker and like you have had a habitation check with no problems reported , so will watch this thread with interest . (y)
PP Bear
7,735
28,114
Kent, UK
Auto Trail Dakota SE
Same here, but never inside the hab area
887
1,043
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
I had the same so double checked every connection was tight then tested with soapy water. Now no smell of gas.
sallylillian
3,944
5,013
Falmouth, Cornwall
Palace Liner 90LO
I have the Gasit rubber hoses and a whiff too. My electronic sniffer does not register any issues with any joints and I have had 2 German gas checks, these were done at the factory when the van was there for warranty and the German motorhome gas law is stringent, both times passing and certificates and stickers issued.
4,270
11,303
Home of the war horse
burstnar T640
Same with ours with rubber pipes I think it may be time for a change to steel braided
Check all the holes in floor of locker are clear I had a bit of junk stored in there after removing it did make a difference
365
448
Shenfield, Essex
Carthago Malibu PVC
35+ years mainly in VW's
I have this in my van as well (no smell in the van, only in the locker). I've checked all the joints with a leak detection spray, but nothing shown. I have the rubber hoses but didn't realise that the smell could permeate through them. It's in for a hab check within the next month and that is on the list to be checked, but will watch this with interest
Trevor
7,451
25,837
Cheshire
C Class Elddis 175
8+ years
We have a gaslow system with st steel hoses, no smell at all. previously we had calor propane with rubber hoses but cannot recall a smell of gas then either. Best to obtain a leak detector spray and check all the connections to be on the safe side, youcould use soapy water with a clean brush as a quick preleak check until you get some leak detector spray
1,367
3,314
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
Yes this one leaks !:eek:
- Dont try this at home by looking for gas leaks with a naked flame! - its fire training in the Philippines - and I wont suggest sending kids into the gas locker with some matches to look for those leaks :cautious:
TerryL
6,152
8,137
North East
Low Profile
I've always had a slight smell of gas inside the locker, twin Gaslow system, outside filler, S/S hoses. Despite a couple of pressure tests, leak detectors and a sniffer thing I've never been able to trace a leak. However LPG does have quite a pungent smell and the small spurt of gas when the filler is disconnected could I suppose condense onto something.
I check the connections regularly and of course keep it well ventilated. Don't know what else to do so just keep an eye (or nose) on it.
19,498
51,185
uttoxeter
ambulance conversion
50 years
Just my two penath, don't know anything but ours does it and I've put it down to the smell lingering after fillup
DanielFord
3,020
3,086
Ours smells, and so have all of the vans we've rented, so I'll go with perfectly normal! :D
Trout bum
567
584
Ayr
Adria Matrix M670SL
Do a check with soapy water mix, or leak detector fluid make sure it's done on flow i.e. Gas bottle turned on check all connections in gas locker , if no leaks wipe residue off connections and hose , you will always get a fishy/ slight garlicky smell from propane gas , especially from the gas hoses , it just lingers on , also make sure the gas locker vent area is clear .
mikebeaches
5,346
8,469
Bristol
Rapido V68 Van Conversion
Since 2009
Noticed it more previously in the gas locker of 2 coachbuilts (Calor bottles), less so in the locker of our current panel van conversion (1 Gas-it refillable, with external filler and 1 unused Calor bottle for back-up)??
All rubber connections.
Wikky
342
664
Cambridge
Rapido 7065+
Since 2003
I have 2 calor propane cylinders and a Truma switchover system, Truma crash shut off valves and rubber hoses. Faint smell of gas in the external locker but no leaks (professionally checked).
Must be normal. Not sure if it happens with Butane.
9,319
24,565
Derbyshire
Elddis Accordo 105
since 2014
Never smelled it in ours. 2 x LPG with braided metal hoses.
What I have noticed though is when I first switch the gas on after being off for months, it has to pressurise the system so it gets out somehow over time. The pipes get full of Air too, I draw the gas to the hob and it won't light at first so it must be air.
1,469
2,711
UK
Burstner Travel Van
Few years now
Same, slight smell of gas in the locker but not the van. I have a hab check in a couple of weeks, so will see if that identifies anything.
