Tyres (2 Viewers)
Jan 22, 2014
1,656
1,140
Birmingham
Coach built
I do think that MH, caravan, trailer tyres are totally different from car, van, truck tyres as they are mostly stood standing in one position for most of the year with all the weight on a credit card size piece of the tyre.
My van moves as well done 33000 in 2 years . From new
Feb 24, 2013
13,088
101,491
Bolsover, Derbyshire
Hymer S800
not long enough
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Delivery is cheap fitting is about £10 each if you shop around and you can do one at a time if needed. So say £140 per wheel thats £560
His price was for Continental
A new set of Continental Vanco tyres are circa £675 fitted..
Techno
Jul 28, 2010
15,475
20,756
May 2010
So what van are you trying to attach a spare to?
jumar
3,779
11,625
Spain
Hymer Tramp
Since 1994
Fortunately only a small hole in the wheelarch, but severe damage to my wallet, but nobody died or was injured. That police were not impressed when I told them my breakdown service had been contacted. Alliance Insurance. MADRID. Its only a phone call away they arranged a local garage to change my tyre and I was on my way again. Crisis avoided. You wouldn't be advised to try to change a tyre in a live carriageway on a motorway or even on the hard shoulder, get behind the barrier, high viz jackets on, Triangle out and pray nobody rams you up the rearend. Hazards also I know.
g8ysn
638
417
ng219ep
had mine changed this year front on back /back on front advised still in decent condition,no crack or deteriation paint with a german tyre black twice a year, advised 7 yrs from new, only done 10.000
Nov 18, 2011
11,862
43,046
Planet Earth
A van
Over 25 year's
This is tread delamination, caused by overheating .. due to under inflation and or overloading.. used to be common on budget retreads ..
it's called tyre belt separation in the trade could be cased by bumping up curbs pot holes running over blunt objects under inflation and over loading to name but a few
bill
2,344
10,180
bill
served my apprenticeship in 'the trade' Bill at India Tyres.. .. but what's in a name .. the tread parts company with the casing..
bumping kerbs and or potholes doesn't generally cause delamination.. that will damage the side walls ..
for more reading , it's almost word for word what I wrote and I didn't copy paste
Understanding Tire Delamination
The most common cause for tire delamination is excessive heat. This is often due to under-inflation, or over-inflation and overloading, in particular, on hot road surfaces. Finally, the age of the tire is important. Tire manufacturers are now suggesting that a tire should be replaced after about five years regardless of wear.
jumar
3,779
11,625
Spain
Hymer Tramp
Since 1994
The tyres in question were Michelin Agilis Camping, the photo fails to show the hole in the side wall, which in my opinion was the cause of the loss of air, together with the 300 metres it took to stop the 3,500kg of motorhome, you would expect some tyre breakdown. So the earlier post is correct, running on under inflated tyre can cause this type of damage.
tambo
874
639
Dunfermline fife scotland
a class
You should have taken a better photo :p
Diesel
150
60
Birmingham
im a newbie
You made it ? Impressive .....my OCD Geeky side is coming out I recognised the tyre from tread pattern :xgrin:
For purpose of sharing data just found this ....leaning towards Coni four season ....ok its old ...heavily weighted to Coni's and no idea if independent
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Problem with Underside Stowage is access is near impossible once a Tyre is flat!. Especially if the Jacking point is over soft ground! I took to carrying a spare Tyre and not a full wheel. As I had no chance of changing it in situ but the recovery / tyre Fitters had a (correct) replacement tyre to work with!.
Pete
Sep 10, 2013
1,187
18,726
Chelmsford Essex
Getting better
Tyres and UV degradation all a bit of a quandary. In USA and Australia, both rather more UV than here not considered an issue to my knowledge.
Diesel
150
60
Birmingham
im a newbie
Pete
Carrying a spare in a spot where you could store other stuff is fine .......if you have a winnebago :ROFLMAO::ROFLMAO::ROFLMAO:
Puddleduck
12,386
44,007
Scottish Borders
Without at present
On and off for many years.
Pete
That's what we do. The hose reel fits inside the spare tyre :)
11,956
16,570
ScotJim's info looks like it came from the US?
