tv/sat/12v/240v/ a little advise please (1 Viewer)
Leswil
4
west lothian
I'm a newbie
Hi I am a newbie having just bought a 2005 Bessacarr E745.
The old owner did not explain all I need to know and it may be I am not doing things right.
1, Old owner had a sky box installed with a £20 sky card. They generally only stayed only on hook up sites , no wild camping.
I want to fit a Freesat box instead of the sky box, I plugged my 240v tv into what I think is a 240v socked ( it took a standard 240v plug) after I hooked it up to my house electrics.
The tv lit up but then went out. I replaced the fuse (5 amp) but it is now dead, so I have had to hand it in for repair. The question is, what did I do wrong? I need to know to avoid a repair bill every time I try it. There is no real hints in any of the manuals supplied with the vehicle.
Any suggestions anyone? They will be much appreciated.
Les:thumb:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
You don't sound as if you have done anything wrong.
Do other 240v appliances work from the 240V motorhome sockets?
bobandjanie
8,164
15,804
Javea, Spain
Pilote V600g
Try a lamp as suggested to you on an earlier thread. much less costly to replace a bulb. If that
does not work check the fuses. If it blows the bulb then see an auto electrician. I am not the electrician in the family but could there be a problem with the hook up lead?
Oh if the lamp does work..... oy, Jim, where is the head scratching emoticon? Jane :Smile:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
19" 12 volt TV with built in DVD from ebay £100......12 volt freesat box from Maplins £40.
Job done except for the satellite dish....that's were your problems really start.
Satandpcguy
Jun 18, 2008
693
421
Gandia, Valencia, Spain
Don't own one yet
None
Note that a Sky box, even with no viewing card, gets exactly the same channels as a freesat box.
So unless you want to change that for a Freesat HD box, or a Freesat PVR, then why bother changing it?
haganap
12,762
26,456
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
my understanding is he wants a 12v sat box? so im asuming the sat box at present is not 12v but an ordinary skybox.
guess we will never know unless he subscribes :RollEyes:
