Torx bolt seized head ruined (1 Viewer)
Jan 1, 2014
580
1,363
France
Pilote G691 LCE
Since 1974
First question, do you want to re-use the part?
If no then try some of previous "suggestions", if yes then a bolt TIG welded onto the old one, will almost definitely work, that also utilise the heat of some of the other suggestions.
Access is very limited so not an easy one.
Jan 4, 2020
416
572
West Yorkshire
Globecar Campscout
Yes, the suspense is insidious and interfering with my tranquillity. When will we know?
6
63720
Perhaps the cabinet needs to make a joint decision and release, see what I did there?, a reply on the 21st 😁
R
Robert Clark
We’re away in the van so only limited tools
Back home Monday for the next thrilling episode
As a teaser …..
Severe heat is not an option as close to the screw are plastic parts and cables
Two on Tour
10,484
52,545
Elddis Autoquest 175
How about drilling through the side of the heads and inserting a small bar as a lever to get some force on the bolt heads
Best to drill at the 4 oclock position to give a bit of swing. Use something like an allen key or a drill bit than is less likley to bend.
Try using a pair of pliers on the lever close to the bolt head to get you a bit more grip.
Keep the hole size as tight to the diameter of the lever you use.
R
Robert Clark
Try using a pair of pliers on the lever close to the bolt head ti get you a bit more grip.
Thankfully it’s only the top one that’s gone
I’m wondering about carefully heating up the head with a soldering iron to make it expand, then hammering in a Torx or Alan bit, then wait for it to cool and contract
Aug 18, 2014
24,015
136,529
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Even better would be drive in a torx or allen bit then use the hexagonal adaptor for the bits in a battery drill on 'hammer' to undo in reverse. Even better would be a 1/2" battery nut runner. but the drill should do it easily
Two on Tour
10,484
52,545
One of the methods I have used in the past with success, is to heat the area and then apply "PlusGas" penetrating oil as best you can around where the head meets the threads and as it cools down the Plus Gas is drawn in by capillary action. Doing this a few times may get some lub into the threads to help get it moving.
Jan 19, 2014
9,451
24,983
Derbyshire
Elddis Accordo 105
since 2014
May 31, 2015
11,915
45,566
Ducato PVC
Getting Better
If the recess is wide enough around it you may be able to tap a small socket over the screw head and unscrew like a socket nut…?
I’ve done this on wheel locking nuts where I’ve lost the key..😆
R
Robert Clark
R
Robert Clark
No it’s a tight fit
R
Robert Clark
Debs
6,329
184,201
West Notts
A class Adria Vision
I can't believe your post has generated 3 pages of replies Robert :laughing:.
Fingers crossed that the speedout kit works!!!
