Hammer on a star socket
Drill a hole [through the side of the head] large enough to insert a screwdriver shaft or similar to get the bolt moving? Or use the smallest set of needle nosed mole grips laid flat to grip by the tips of the grips [free poetry!]Sadly there is little access to the head
I’ll try the stud remover when we’re home
It’s a t25 head - Amy idea what thread size that corresponds to ?
Robert Clark
i cant wait to find out how you got it out and who won the prize of a 'gnarled' torx bolt ..... i have so many ideas of what to do with it if i win .....
My experiences of "easy outs" and seized bolts is that they're more likely to cause further damage than anything else, making it even more impossible to remove the bolt without causing further damage. I once managed to crack a cast iron engine block using an easy out.Because of the limited access I’d drill it out deeper and use the ‘easy out’ stud extractors already mentioned.
Worked brilliantly on my Triumph crank sludge trap plug, notoriously difficult to remove. You must use the right size and have it in far enough though, many folk have snapped them, then your in bother.My experiences of "easy outs" and seized bolts is that they're more likely to cause further damage than anything else, making it even more impossible to remove the bolt without causing further damage. I once managed to crack a cast iron engine block using an easy out.
Have you tried the elastic band a LBS?On a different note I was surprised to discover that one T25 screw was M6 and the identical screw on our other bike was M5
Will be trying that !Have you tried the elastic band a LBS?
It's the final temperature that matters. Aluminium and stainless steel are both good conductors of heat so it will spread quickly. Aluminium expands more than stainless steel, so the hotter the better. In case you're wondering, a hole expands just as much as the solid metal.Before I apply heat, should I apply WD40?
How long should I apply the heat for?
What about WD40 ?It's the final temperature that matters. Aluminium and stainless steel are both good conductors of heat so it will spread quickly. Aluminium expands more than stainless steel, so the hotter the better. In case you're wondering, a hole expands just as much as the solid metal.
Yes neither would I.My experiences of "easy outs" and seized bolts is that they're more likely to cause further damage than anything else, making it even more impossible to remove the bolt without causing further damage. I once managed to crack a cast iron engine block using an easy out.
