Thingie on the Roof (2 Viewers)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I have a strange thingie on the roof of my 'new' (old) hymer. Fibreglass box, and inside a roof device that is either a very early aircon unit, or a ceiling mounted lawnmower. No idea how it works, if indeed it does. Maybe a re-humidifier? Thought to ask before exploring further.
Dave.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Dave.
Perhaps a picture?
Could be an evaporative cooler, but you may need to work on the description.
Jun 30, 2010
7,925
27,235
1992 VW Auto sleeper Mono
Since 2005 this time
AH HAAA ! so this is where my Planet Exscurewtiator Blambnasical minoriatort ended up:Doh:
What ever you DO! DON'T TOUCH THEC RED BUTTON!!!!!:Doh:
Jun 30, 2010
7,925
27,235
AH HAAA ! so this is where my Planet Exscurewtiator Blambnasical minoriator ended up:Doh:
What ever you DO! DON'T TOUCH THE RED BUTTON!!!!!:Doh:
JJ
Mágica
May 1, 2008
19,259
48,056
Burstner Privilege T
over 50 years
I am willing to bet it is a Travel Cool 12 volt aircooler.
Don't you have vents etc and switches under it inside the van?
JJ :Cool:
Whoops... sorry ... photo bit dark...
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Perhaps a picture?
Well, you TRY and be serious!! :Doh:
OK, its WHITE, with something like BLACK lawnmower blades at each end........That's inside. Outside it looks like one of those silly helmets that racing cyclists wear. A bit, anyway. The guy I bought the van off said it had pipes that led somewhere............The inside bit is halfway down the corridor, dead centre of the ceiling.
Maybe it is a dead racing cyclist??
23,836
72,546
Aww now come on Rangi.....you just made that name up, didnt you :RollEyes:
No PJ, there really is something called a red button ! :thumb:
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
JJ :Cool:
HA! The very animal!! Thank you. ...........er, how does it work??:Blush:
JJ
Mágica
May 1, 2008
19,259
48,056
over 50 years
Ok.
You should have a water container somewhere with a pump.
On the unit inside mine there is a pump switch (on/off) and a fan switch high/off/low and a blow air in or extract air out switch.
When you switch on the pump it draws water up from the tank, into the thingy on the roof where it soaks a filter like material. The surplus water returns to the tank so in effect water goes around and around. Choosing "air in" option and switching on fan will result in the unit sucking air in from the outside, over the evaporator, which cools it down, and into the van. You can direct the flow of cool air a bit by swivelling the vents.
It does not cool as much as a grown up air conditioner but it does lower the temperature quite a bit and is refreshing if you position yourself in the airflow.
The great thing about the system is it works on 12 volts and can be used when driving.
Don't forget to keep the water container topped up.
I reckon if you Google Trav L Cool you will find a full user manual and maintenance guide.
JJ :Cool:
