Thingie on the Roof
Discussion in 'Motorhome Chat' started by Tootles, Sep 15, 2013.
  1. Tootles
    Tootles Funster
    Sep 14, 2013
    9,106
    32,036
    Lancaster
    I have a strange thingie on the roof of my 'new' (old) hymer. Fibreglass box, and inside a roof device that is either a very early aircon unit, or a ceiling mounted lawnmower. No idea how it works, if indeed it does. Maybe a re-humidifier? Thought to ask before exploring further.
    Dave.
  2. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    Perhaps a picture?
    Could be an evaporative cooler, but you may need to work on the description.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,322
    YO11 2BD
    as they say......a picture paints a thousand words.
    • Like Like x 1
  4. rangitira
    rangitira Funster
    Jun 30, 2010
    6,321
    12,781
    Cornwall
    AH HAAA ! so this is where my Planet Exscurewtiator Blambnasical minoriatort ended up:Doh:
    What ever you DO! DON'T TOUCH THEC RED BUTTON!!!!!:Doh:
    • Like Like x 2
  5. pappajohn
    Aug 26, 2007
    29,704
    17,322
    YO11 2BD
    Aww now come on Rangi.....you just made that name up, didnt you :RollEyes:
    • Like Like x 1
  6. rangitira
    rangitira Funster
    Jun 30, 2010
    6,321
    12,781
    Cornwall
    AH HAAA ! so this is where my Planet Exscurewtiator Blambnasical minoriator ended up:Doh:
    What ever you DO! DON'T TOUCH THE RED BUTTON!!!!!:Doh:
  7. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,680
    doncaster
    you had two of them and lost them both?
    • Like Like x 2
  8. pappajohn
    Aug 26, 2007
    29,704
    17,322
    YO11 2BD
    see...i told you so.
    you spelt it correctly the second time round :thumb:
    • Like Like x 1
  9. rangitira
    rangitira Funster
    Jun 30, 2010
    6,321
    12,781
    Cornwall
    WHO ME? would I do such a thing?:Smile:
  10. JJ
    JJ Funster
    May 1, 2008
    14,649
    25,990
    I am willing to bet it is a Travel Cool 12 volt aircooler.
    Don't you have vents etc and switches under it inside the van?
    JJ :Cool:
    Whoops... sorry ... photo bit dark...
  11. Tootles
    Tootles Funster
    Sep 14, 2013
    9,106
    32,036
    Lancaster
    Well, you TRY and be serious!! :Doh:
    OK, its WHITE, with something like BLACK lawnmower blades at each end........That's inside. Outside it looks like one of those silly helmets that racing cyclists wear. A bit, anyway. The guy I bought the van off said it had pipes that led somewhere............The inside bit is halfway down the corridor, dead centre of the ceiling.
    Maybe it is a dead racing cyclist??
    • Like Like x 1
  12. JJ
    JJ Funster
    May 1, 2008
    14,649
    25,990
    So it isn't what I thought then?
    JJ :Cool:
  13. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,583
    22,481
    Narrfoook
    No PJ, there really is something called a red button ! :thumb:
    • Like Like x 1
  14. Tootles
    Tootles Funster
    Sep 14, 2013
    9,106
    32,036
    Lancaster
    HA! The very animal!! Thank you. ...........er, how does it work??:Blush:
  15. JJ
    JJ Funster
    May 1, 2008
    14,649
    25,990
    Ok.
    You should have a water container somewhere with a pump.
    On the unit inside mine there is a pump switch (on/off) and a fan switch high/off/low and a blow air in or extract air out switch.
    When you switch on the pump it draws water up from the tank, into the thingy on the roof where it soaks a filter like material. The surplus water returns to the tank so in effect water goes around and around. Choosing "air in" option and switching on fan will result in the unit sucking air in from the outside, over the evaporator, which cools it down, and into the van. You can direct the flow of cool air a bit by swivelling the vents.
    It does not cool as much as a grown up air conditioner but it does lower the temperature quite a bit and is refreshing if you position yourself in the airflow.
    The great thing about the system is it works on 12 volts and can be used when driving.
    Don't forget to keep the water container topped up.
    I reckon if you Google Trav L Cool you will find a full user manual and maintenance guide.
    JJ :Cool:
    • Like Like x 1
  16. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,803
    Nah, he's always been called Rangi
    • Like Like x 1
