Stove Ignition not working (3 Viewers)
Kiwi Coss
261
796
New Zealand
Our ignition on our stove has stopped working. It happened after we came back after a long break.
Is there a fuse or does it have a separate battery feed?
The motorhome is a Swift Sundance 2006. Stove is a Thetford.
Any advice would be greatly appreciated.
Colin Cossey
23,836
72,548
What electrical system is fitted ( Sargent etc etc ? )
And in what MH is it ?
Kiwi Coss
Kiwi Coss
261
796
New Zealand
Don't know what electrical system is fitted. We wild camp all the time so only use 12v from the leisure batteries.
Ignition system to the fridge to ignite the gas works OK. so I am thinking the stove is on a separate supply. It is a Swift Sundance year 2006. Stove is a Theford.
Kiwi Coss
Kiwi Coss
261
796
New Zealand
Been doing that but you know what the other halves are like they want everything working. Also after the gas explosion in the MH a few years back she is reluctant to ignite the oven part and I would like a roast now and then. She is happy to use the gas lighter on the top so I can get a cuppa tea. Would like to get it fixed as I don't want her having a reason to stop all cooking.
Just ignore me, I'm jealous, we don't have electric ignition. You have my sympathy, other halves take some getting used to, I'm still trying 50 years on.
23,836
72,548
Ahh.. Its a Swift and has a Sargent system fitted
have a look around and see if you can see a gray box ( often under a seat ) with some fuses in it.. The wire that feeds the cooker ignition ends up in there ( at least it does on my set up )
I cannot remember if there is a fuse on the circuit but THINK there might be.
My feed wire actually went faulty in the loom somewhere so a separate thin wire was run to a switched 12v line in the box.
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Make sure you are switched on at the wall. ( maybe above door) i' m sure my cooker works on a different circuit.
When i travel it shuts the system down and needs to be switched on again, before my cooker water pump and toilet flush and cabin lights
I can keep the tv/dvd and one light at belted seats on whilst moving.
Kiwi Coss
Kiwi Coss
261
796
New Zealand
Thanks. Will check it out and see how I get on and let you know.
Kiwi Coss
Kiwi Coss
261
796
New Zealand
Thanks but it dosen't have a separate supply like that. I have a switch above the door for the water pump, outside light, water level indicator, batt level indicator, and switch between vehicle and leisure batts.
Thanks for the info.
Kiwi Coss
Kiwi Coss
261
796
New Zealand
Ahhhh then I only have another 10 or so years to catch up. If you find the secret let me know....Ha ha
Bobby22
1,537
6,408
Rapido 680ff
since 2013
If that main switch isn't on then my igniter won't spark.
DanielFord
3,020
3,086
We have a 2011 sundance, the igniter will not work if the power on the control panel is off. Also, there is a supply switch at the bottom back in the narrow cupboard, check you haven't knocked into the off position.
There is a possibility that the igniter on the older model is of the type with a battery. If this is the case, unscrew the igniter button, there will be a battery behind it.
Kiwi Coss
Kiwi Coss
261
796
New Zealand
Thanks Will check it out
Aug 27, 2014
1,910
3,935
Shropshire
McLouis Tandy 640+
Since 2014
On our oven occasionally the spark igniter stops working. A quick rub of the end of the electrodes with my thumb and it comes back into life! I keep meaning to give the electrodes a quick gentle clean with a bit of fine emery cloth at home, I keep forgetting, might even go and do it tonight now that I've remembered.....
The position of them seems to make them vulnerable to getting mucky.
