Depens on a persons ability some are better DIY'ers than othersThought it was supposed to be a diy fit?
Using a garage adds to the cost.
The whole idea of the project was to show and review the ease of fitting etc ( supposed to be a DIY job) as part of the review.Depens on a persons ability some are better DIY'ers than others
Bumpdpsuk999 - have you fitted it yet? Any good?
Just been reading about it and it had 3 different modes which does include a ‘service’ mode
Once I’ve received it and fitted it I’ll give a full review
Mk10,,one of Jaguars best,,BUSBY.There's a MK10 out now
After the Vi2 E-Type i would agreeMk10,,one of Jaguars best,,BUSBY.
As I understand it, you can enter a code to over ride the engine blockerKeen to see this review. Sounds like a good idea. Bit concerned what happens if your phone is dead or broken.
Good point. Could be a nightmare if it cuts out driving down the motorway. Maybe they have thought of that and it only operates during starting the vehicle.If only bluetooth was 100% reliable. The connection to my Panasonic stereo fitted in the Ducato cab drops out randomly at a range of less than 2 foot. This does not creat trust or confidence.
I would expect you need Bluetooth on while you running the engine only.When a review becomes available I would want to know what happens if you're a non Bluetooth on all the time phone user.
Would I need to turn Bluetooth on to start my motor every time or could I just return to find my van stolen and then activate Bluetooth in order to shut the engine down ?
As the keys are with us if the van were to move out of range of the keys Meta contact me to advise and then I would want to activate it as it won't have gone too far
I have never turned off my Bluetooth if you send them an email they will confirm the situationWhen a review becomes available I would want to know what happens if you're a non Bluetooth on all the time phone user.
But the damage caused by the thwarted thief was to plastic trim and wiring looms all Fiat, all plug in, clip (screw) on replaceable parts, all covered by InsuranceI am seriously thinking of fitting one as they seem better than a none starting device, If someone is trying to steal your van and it won’t start they rip the dash apart as seen on here with the vanbitz none starter they never got the van but the damage was thousands.
Or driven off if your blue tooth has connected to your Sonos or myriad of other house hold Bluetooth devicesWhere as this unit will allow the engine to start and run for a short time then the engine will die and the horn sounds to attract attention once on the road,
A £120 gadget that can stop my engine when I am driving it !most thieves will not mess about on the side of the road trying to get a vehicle started at a cost of £150 also 20% MHF discount so £120 what’s not to like.
Well, everyone has different experiences using it I guess, I get annoyed how often my car for example, decides to connect to my wife’s phone which is with her, in the house, when I’m sat in the car, with my phone in the car, driving off then the car tells me I can’t change as ‘I’m driving’So Bluetooth is an unreliable connection?
some say 2 feet you say 1 kilometre it’s not good enough to keep your engine running but it’s good enough to get your engine running if your imobiliser failsWell, everyone has different experiences using it I guess, I get annoyed how often my car for example, decides to connect to my wife’s phone which is with her, in the house, when I’m sat in the car, with my phone in the car, driving off then the car tells me I can’t change as ‘I’m driving’
One thing I do know is that Bluetooth can work up to Kilometre, and I wouldn’t want my van being driven away by a thief that far before my security worked.
Very valid point this and a huge reason not to fit it if trueDifferent story if your driving 4 ton of motorhome down the motorway, on a dark wet road and the engine cuts out!
Brakes, steering and power gone!
