Solar panel (1 Viewer)
Goronwy
56
18
Varies
Hi top
Since 2008
Advice required on what portable solar panel funsters have found best for charging I Pad,Kindle,Mobile phone.
19,369
30,349
You should be able to charge your devices from your 12 volt battery so the solar panel would be to recharge the 12 volt battery. If you need a solar panel the easiest is to stick 100 or 120 watts on the roof but otherwise a 60 or 80 watt portable solar should do OK keeping you topped up.
G
Goronwy
56
18
Varies
Hi top
Since 2008
Thank you, however the type of panels I am considering are the ones you can plug the appliances directly into so can be used independently when away from the van.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
The ones you mention that you plug directly into are very small low output for backpackers hardly worth the bother
12W 1400ma 1.4 amp midday, mid summer full sunshine rest of the time days to charge an ipad if not weeks.
Size matters. You've got to need at least a foot square, better bigger. Modern smart phones have serious batteries inside. You need 2A at 5V at least to get the job done.
G
Goronwy
56
18
Varies
Hi top
Since 2008
Thank you,that's useful to know.
G
Goronwy
56
18
Varies
Hi top
Since 2008
Thank you for information,it's all helping.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Portable solar for charging is useless. As a scout leader, I have seen several types tried out. Personally, I carry the likes of this in the ruck sack.
G
Goronwy
56
18
Varies
Hi top
Since 2008
Thank you for the advice , I don't think I'll pursue the portable solar option for charging I pad,mobiles etc. Asking the question has been very worthwhile ,many thanks to all who have replied.
AlexHamilton
USA
Thanks for your advice.. I do need to add these panels on my home roof and I will follow your advice..
ukbill
5,501
5,274
Pinoso
4 berth low profile
i bought 1 of those ages ago and it always topped up my phone etc with no problem
AlexHamilton
USA
You should be able to charge your devices from your 12 volt battery so the solar panel would be to recharge the 12 volt battery. If you need a solar panel manufactured in solar panels factory the easiest is to stick 100 or 120 watts on the roof but otherwise a 60 or 80 watt portable solar should do OK keeping you topped up.
Got the panels will install them soon..
