Solar panel
Discussion in 'Solar Power' started by Goronwy, Oct 7, 2014.
  1. Goronwy
    Goronwy
    Apr 29, 2014
    56
    18
    Varies
    Advice required on what portable solar panel funsters have found best for charging I Pad,Kindle,Mobile phone.
  2. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,085
    5,371
    Guisborough
    You should be able to charge your devices from your 12 volt battery so the solar panel would be to recharge the 12 volt battery. If you need a solar panel the easiest is to stick 100 or 120 watts on the roof but otherwise a 60 or 80 watt portable solar should do OK keeping you topped up.
  3. Goronwy
    Goronwy
    Apr 29, 2014
    56
    18
    Varies
    Thank you, however the type of panels I am considering are the ones you can plug the appliances directly into so can be used independently when away from the van.
  4. funflair
    Dec 11, 2013
    5,085
    5,371
    Guisborough
    sorry, I know nothing.
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,603
    Ilfracombe, Devon
  6. hilldweller
    Dec 5, 2008
    27,180
    26,154
    Macclesfield
    Size matters. You've got to need at least a foot square, better bigger. Modern smart phones have serious batteries inside. You need 2A at 5V at least to get the job done.
  7. Goronwy
    Goronwy
    Apr 29, 2014
    56
    18
    Varies
  8. Goronwy
    Goronwy
    Apr 29, 2014
    56
    18
    Varies
    Thank you for information,it's all helping.
  9. SuperMike
    SuperMike Funster
    Apr 28, 2010
    987
    1,111
    St Albans
  10. Goronwy
    Goronwy
    Apr 29, 2014
    56
    18
    Varies
    Thank you for the advice , I don't think I'll pursue the portable solar option for charging I pad,mobiles etc. Asking the question has been very worthwhile ,many thanks to all who have replied.
  11. AlexHamilton
    AlexHamilton Read Only Funster
    Oct 13, 2014
    USA
    Thanks for your advice.. I do need to add these panels on my home roof and I will follow your advice..
  12. ukbill
    ukbill Funster
    Nov 3, 2011
    4,927
    4,881
    benidorm
  13. AlexHamilton
    Oct 13, 2014
    USA
    Got the panels will install them soon..
