solar panel (3 Viewers)
boris
8
brewood
Rapido
Hi, i am a new member and would like to know if anyone new the basics of wiring a solar panel into my Rapido.
I know the + & - wires go from solar panel to the regulator and then to the battery.
but there are then some more terminal connections on the drawing, showing connections to lights etc. "load 1 & 2 ?
am i right in saying you dont connect to these ?
23,836
72,555
Depends on the controller and what you want to do with it, but for basic battery charging what you say is 'perfik' and all you need to do :thumb:
43,339
49,540
the extra two terminals, usually marked with a light bulb, will provide a very low current of around 2amps at most to feed back from the battery through the controller at night for a porch light etc..
not worth the trouble wiring it in.
B
boris
8
brewood
Rapido
Thanks for that. I will be fitting it all tomorrow night after work. cus we are off to "scotland on Saturday for 2 weeks yippee!!
Jul 28, 2010
1,710
617
The world
Small car
be sure to cover the panel so it is not live when doing the wiring connections
simple mistake to short it out
43,339
49,540
when you get round to fixing the panel to the roof make sure you tape the exposed ends of the panel wires or cover the solar panel with cardboard/towel/sheet etc......in sunlight they can carry over 17volts and if shorted together may damage the panel.
B
boris
8
brewood
Rapido
thanks for that. i would not have thought of it so, nice one
Fitting a solar panel for Scotland. Now there's optimism. Is it to run an electric midge zapper ?
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
I wired my spare terminals to a 12v ciggar socket and charge my phones and torch for free:thumb:
It should be noted these spare terminals will only be live when the batteries are full,ish, when they drop below a certain threshold the regulator will cut supply to them and send all available charge to the leisure batteries, when full again any spare power is sent back to the phone/torch socket, as John said at about 2 amp max:Cool:
G
B
boris
8
brewood
Rapido
True. got my sun tan oil, midge cream, rain mac and back up generator
B
boris
8
brewood
Rapido
G
cheers for info but dont think i'll bother with the faf of extra wiring
43,339
49,540
Oh dear :Doh:.....sun oil (along with any perfumed toiletries) attracts the little buggers and midge cream is pretty much useless.
if you have the time buy a bottle of Avon 'skin so soft' skin cream/softener (blue-ish green label)
the Army/SAS use it when on manoeuvres in Scotland, so it must work.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Not usually the case, loads 1 and 2 are for connecting everything up to the total wattage of the controller, then when the battery falls to a preset level those loads will be disconnected to protect the battery. I run my TV, sat system and inverter ect from the load rather than direct from the battery. Not only do you get protection for the battery but you also get voltage spike protection as it is a regulated output. These facilities are usually ignored but they are there for a purpose. The Rapido does I believe could be wrong I often am) have a Schudlt electrabloc fitted to handle all of the electrics in the van that being the case it is possible to get a matching regulator to plug straight into the electrabloc rather than connect straight to the batteries. The advantage of this is the ability to charge the engine battery as well as the hab battery.
B
boris
8
brewood
Rapido
is it ok to just bed the solar panel down on silicone, it has an aluminium frame about 1 1/2" I have a plastic junction box siliconed to the roof above the wardrobe for the wires to go through.
43,339
49,540
may be the case on some Rogr, but the controller on the kontiki had a max load of 2 amps and only worked when the panel was 'dead'...ie night time.
basically if the panel was producing power it switched off the aux output....hence me saying it is for a porch light etc.
B
boris
8
brewood
Rapido
think we'll go to France instead then, at least i can test the solar panel
tonka
10,834
21,544
Cannock, Staffs
A class Burstner 800
Since 2000
I cant see that its been mentioned yet But..
Connect the regulator to your leisure battery FIRST, leave it on a few mins and connect the solar panel last..
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
The reason for that John is the contoller used was intended for automatic lighting rigs, however there is a setting Number 6 if memory serves correctly that allows output all the time and you could use the red button to switch on and off if you held the button down for a longer time it would change the programable settings for automatic varying lengths of light on. Cheapo controllers not original intended for motorhome use. I did run my TV etc though one of those in the old beast. But even then output was the same as controller was rated at. 10amp From memory, I still have the paperwork so will look it up.
Kayold
60
35
Derbyshire
1 year M/H, caravans 20+ yrs
May I ask, if these usually unused connections were wired to a 12v socket or inverter would an additional fuse be required between the controller and new outlet?
Theonlysue
6,104
7,383
As Executive 50th an
Not long enough!
Hi,
I thought that you had to leave a gap between the panel and roof for air flow to keep it cool? hence brackets seemed to be usually used
S
23,836
72,555
There is an old saying, you can never have enough fuses !
OK, strictly speaking that is not exactly true, but a feed line that is fused is always safer than one that isn't :Smile:
