solar panel
Discussion in 'Motorhome Chat' started by boris, Aug 7, 2012.
  1. boris
    boris Read Only Funster
    Aug 7, 2012
    8
    brewood
    Hi, i am a new member and would like to know if anyone new the basics of wiring a solar panel into my Rapido.
    I know the + & - wires go from solar panel to the regulator and then to the battery.
    but there are then some more terminal connections on the drawing, showing connections to lights etc. "load 1 & 2 ?
    am i right in saying you dont connect to these ?
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,958
    23,796
    Narrfoook
    Depends on the controller and what you want to do with it, but for basic battery charging what you say is 'perfik' and all you need to do :thumb:
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,368
    18,055
    YO11 2BD
    the extra two terminals, usually marked with a light bulb, will provide a very low current of around 2amps at most to feed back from the battery through the controller at night for a porch light etc..
    not worth the trouble wiring it in.
  4. boris
    Aug 7, 2012
    8
    brewood
    Thanks for that. I will be fitting it all tomorrow night after work. cus we are off to "scotland on Saturday for 2 weeks yippee!!
    • Like it Like it x 1
  5. motorhomelover
    motorhomelover Banned
    Jul 28, 2010
    1,719
    613
    The world
    be sure to cover the panel so it is not live when doing the wiring connections
    simple mistake to short it out
  6. pappajohn
    Aug 26, 2007
    30,368
    18,055
    YO11 2BD
    when you get round to fixing the panel to the roof make sure you tape the exposed ends of the panel wires or cover the solar panel with cardboard/towel/sheet etc......in sunlight they can carry over 17volts and if shorted together may damage the panel.
  7. pappajohn
    Aug 26, 2007
    30,368
    18,055
    YO11 2BD
    beaten to it once again :Doh:
  8. boris
    Aug 7, 2012
    8
    brewood
    thanks for that. i would not have thought of it so, nice one
  9. hilldweller
    Dec 5, 2008
    27,885
    26,962
    Macclesfield
    Fitting a solar panel for Scotland. Now there's optimism. Is it to run an electric midge zapper ?
    • Like it Like it x 2
  10. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,896
    6,157
    Mansfield,Notts
    I wired my spare terminals to a 12v ciggar socket and charge my phones and torch for free:thumb:
    It should be noted these spare terminals will only be live when the batteries are full,ish, when they drop below a certain threshold the regulator will cut supply to them and send all available charge to the leisure batteries, when full again any spare power is sent back to the phone/torch socket, as John said at about 2 amp max:Cool:
    G
  11. boris
    Aug 7, 2012
    8
    brewood
  12. boris
    Aug 7, 2012
    8
    brewood
    True. got my sun tan oil, midge cream, rain mac and back up generator
  13. boris
    Aug 7, 2012
    8
    brewood
    cheers for info but dont think i'll bother with the faf of extra wiring
  14. pappajohn
    Aug 26, 2007
    30,368
    18,055
    YO11 2BD
    Oh dear :Doh:.....sun oil (along with any perfumed toiletries) attracts the little buggers and midge cream is pretty much useless.
    if you have the time buy a bottle of Avon 'skin so soft' skin cream/softener (blue-ish green label)
    the Army/SAS use it when on manoeuvres in Scotland, so it must work.
  15. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    Not usually the case, loads 1 and 2 are for connecting everything up to the total wattage of the controller, then when the battery falls to a preset level those loads will be disconnected to protect the battery. I run my TV, sat system and inverter ect from the load rather than direct from the battery. Not only do you get protection for the battery but you also get voltage spike protection as it is a regulated output. These facilities are usually ignored but they are there for a purpose. The Rapido does I believe could be wrong I often am) have a Schudlt electrabloc fitted to handle all of the electrics in the van that being the case it is possible to get a matching regulator to plug straight into the electrabloc rather than connect straight to the batteries. The advantage of this is the ability to charge the engine battery as well as the hab battery.
  16. boris
    Aug 7, 2012
    8
    brewood
    is it ok to just bed the solar panel down on silicone, it has an aluminium frame about 1 1/2" I have a plastic junction box siliconed to the roof above the wardrobe for the wires to go through.
  17. pappajohn
    Aug 26, 2007
    30,368
    18,055
    YO11 2BD
    may be the case on some Rogr, but the controller on the kontiki had a max load of 2 amps and only worked when the panel was 'dead'...ie night time.
    basically if the panel was producing power it switched off the aux output....hence me saying it is for a porch light etc.
  18. boris
    Aug 7, 2012
    8
    brewood
    think we'll go to France instead then, at least i can test the solar panel
  19. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,767
    8,008
    I cant see that its been mentioned yet But..
    Connect the regulator to your leisure battery FIRST, leave it on a few mins and connect the solar panel last..
  20. Wildman
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    The reason for that John is the contoller used was intended for automatic lighting rigs, however there is a setting Number 6 if memory serves correctly that allows output all the time and you could use the red button to switch on and off if you held the button down for a longer time it would change the programable settings for automatic varying lengths of light on. Cheapo controllers not original intended for motorhome use. I did run my TV etc though one of those in the old beast. But even then output was the same as controller was rated at. 10amp From memory, I still have the paperwork so will look it up.
