Smell From Waste Water Tank (3 Viewers)
trevtherev
37
16
Suffolk
Newie but caravaned 30 years
Any tips on keeping the waste water tank clean and not to pongy. I have improved things by keeping the plugs in but thought it would help by cleaning the pipes and tank but not sure on what to use.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I had this problem, until late last year, when, after starting to use Bio washing machine liquid in the toilet cassette, (instead of blue or green stuff), I poured a cap full down the sink. Hey presto! No more smells!! (y)(y)
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
We find ours is OK unless we drive with a window open then I put some of the bio liquid we use in the loo down the plug hole.
Wondered why there's a sticker in the cab saying don't drive with a window open.
T
trevtherev
37
16
Suffolk
Mine does not appear to have any water traps under the sink, the MH is 10 years old so possibly was made that way. I will clean the system out using the advice given and use some bio washing liquid in the tank replacing the bungs.
Emmenay
505
481
Swift Kon-tiki 600
Since 2011
I used to have the same problem until somebody (can't remember who) on here said that the worst culprit for kicking up a smell in the waste tank is milk, even the tiny amounts that go in there by way of tea and coffee dreggs.
Based on that idea, not one drop of milk has gone into our waste tank for nearly two years, coupled with scraping dinner plates etc a bit more thoroughly, we have not encountered any smells whatsoever, not even in the heat of Spanish summertimes, and that's with no cleaners. (y)
R
Robert Clark
We had exactly the same problem with smelly waste pipes, and like you we don't have traps either.
We found that the water in the black tank was 'stale' even after emptying.
We eliminated the problem by properly cleaning the waste tank by diluting some Fenwicks wateupipe andtank cleaner in a bucket of VERY hot water and pouring down each of the sinks/showers (having first completely emptied that tank) - took the van for a ride to thoroughly agitate the mix in the tank, and emptied out.
Ordinary kitchen soda cyrstals dissolved in hot water would do the trick if you didnt want to by watepipe cleaner.
Our tank was so dirty and greasy that the level indicator had packed up working properly as it was caked in crap.
On a weekly basis we add a little neat watepipe cleaner, or soda crysals directly into the waste pipe.
This basically helps to dissolve any build up of grease / bacterior, which causes the smells.
Haven't had any problems since!!!!
Hope this helps
Regards
Robert
18,038
48,155
The coca cola trick doesn't work in my experience if the tank is really pongy.
What works brilliantly are Dometic Power Care capsules which you can find if you do a bit of Googling. Be warned the blood will drain from your face when you see the price! But, they are so good you won't have to use them more often than about once every couple of weeks of continuous use.
To use them put a capsule in the sink and pour very hot water from a kettle over it. I would only do this in a stainless steel sink as it might stain anything plastic.
The capsules are meant for black waste holding tanks but they work very well in the grey.
Bio washing liquid also useful but if you want to really zap the tank the Dometic stuff is unbeatable. Shame about the price!
Jun 30, 2010
7,925
27,237
1992 VW Auto sleeper Mono
Since 2005 this time
Just a tip: if you are doing yer own dishes: wipe the fat off as much as poss. using kitchen towels,(even better idea! use paper plates)
Also bought some stuff at Trago Mills (If it's there, it's in all Plumbing Merchants) that is used to clean the pipes/radiators etc in Oil Fired central heating, follow the instructions (yeh! Real Men don't do instructions HAH!) Drove around a bit, and! no smells! Result!
MattR
4,105
39,018
Beds
Panel van
Years
Watch what you put down the drain; we were staggered how gloopy pasta water was after cooking and how smelly it became even over night. It would probably coat the inside of the tank with gunk which will be an ideal breeding ground for smell producing bacteria etc.
Brian Haslam
Devon
Hi top
Hi I`m a new-be to the club but have been Motor caravaning for many years and i was given a tip to put some cheep orange squash undiluted ( 1/2 pt ) down the drain and never had smelly tanks , all the best to all . Buzz.
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Caustic soda is the answer!
Don't WASTE your time with anything else I tried all the others to no avail . On my new to me van the waste tank get blocking and being a newbee I didn't know what to do ,tried poking wire up ,pressure washer ,coke etc.
My mum god bless her,couldn't believe I hadn't tried caustic soda,put a good half a mug full into a bucket of water and tip a some down every plug hole in your van then go for a good drive leave overnight then a quick drive and open the tap !
As soon as you open the tap look away and hold your nose ,if it's anything like my van a gooey afterbirth like smelly mass will exit your tank followed by some fluid .Fill the tank and empty a couple of times to flush it and will be well !
Vlad
Jun 17, 2012
2,934
9,946
North Essex
Autotrail Delaware
>12 but <13
Always had really smelly waste tank. Was embarrassed if someone waiting when emptying.
Used 10 x 2 litre bottles of ALDI's diet coke at 17p per bottle. Down sink, washbasin and shower drains.
Drove around and left it for a week before draining. Next time around grey water had no smell at all.
COST ÂŁ1.70 :clap2:
jonandshell
5,476
8,299
Not got one!
Smev 20mm double syphon. It has an integral water trap.
Google it, buy them and fit them.
No more smells.
Keep saying this, nobody seems to listen or they like wasting perfectly good coke by pouring it down the drain.....
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
If you're going down the Cola route, Sainsbury's Basics Cola is only 10p a litre - I use it to clean up old brass and copper items by dunking them for a week in a large plastic container full of the evil stuff in my greenhouse. How anyone can inflict it on children is beyond me.
As for the MH - I just make sure all the plugholes are plugged, then the grey water tank can stink all it likes.
23,836
72,555
A lot of sinks I have seen ( including ours ) do not APPEAR to have a trap fitted, but in reality they are made as part of the actual plug fitting.
In my opinion they are far too shallow to be effective.. I spend 3 quid on a mini bottle trap and fitted it..
A tip passed on to me by Scotties was to dump a couple of litres of fresh orang juice down the plug hole and leave that in while you drive around..
previous to fitting the new trap it worked every time.. Would last a few months and then be redone..
Since the new trap has been fitted no smells at all
Also, as Tremybach points out, if you have a large amount of water in the tank and just open the valve full, it may well suck the trap(s) dry..
We always run a wee bit of water in to the sinks after a tank dump to compensate
18,038
48,155
No more smells.
We don't get smells from the plugholes - it is the smelly water when emptying which offends. :)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
COST ÂŁ1.70 :clap2:
Well I certainly do NOT like the taste of it so it is the best thing you can do with it. I do not know where they get it as the usual standard of goods is excellent.
T
trevtherev
37
16
Suffolk
Had a look at the smev parts ,they look useful. If the smell is coming from the tank Then I assume one of these would need to be fitted under all of the water outlet points, one in the kitchen sink, the shower room sink, and my shower tray has two. Which would have to come up to fit the smev bits to. Quite a job. Or have I got this wrong?
2,355
10,235
both sinks , but lifting the shower tray is impractical and asking for problems.. I'd just keep the plugs in the shower drains..They should already be fitted to the shower.. maybe they are dirty with accumulated soap , hair etc.. try cleaning them..
R
Robert Clark
Replacing traps could be a major job you may regret starting
Why not try the pipe/tank cleaning options first?
If this works you've saved yourself a job
Sep 10, 2013
1,187
18,726
Chelmsford Essex
Getting better
We use cheap runny bleach, not the expensive stuff as it contains foaming agents. So half a bottle down the drains into a half full tank drive for the day, drop waste as normal, tank now sparkly clean....simples.
PS above idea not mine, but from an earlier Fun thread.
Oct 18, 2014
1,858
1,157
Salisbury
Hymer B598 PL
We put a small amount of the elsan tank stuff down each plug hole after emptying waste ready for use.
mentaliss
654
306
Lancing
we use plain Bi Carb of Soda, tea spoon mixed with warm water ...doesn't damage any delicate rubber washers/O rings that may be fitted
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Same here - once grey emptied put a small amount of elsan down each plug hole and about a litre of water on top. Once driving this 'swishes' about and gives the tank a damn good clean. When we then use the van again the grey waste comes out smelling sweet - no stink.
Have been behind some at the emptying point and they have nearly been knocked out by the stink - five mins as above before you leave site and voila,,,, sweet grey tank.(y)
Trikeman.;)
Nov 18, 2011
11,862
43,072
Planet Earth
A van
Over 25 year's
clean with calgon half fill tank dissolve a hole box in hot water poor down all your drains drive round with it for a few days then dump the contents of tank at a sutibill location fill with clean water to swill tank
then after that when ever possible do not close your tank dump when van not in used
from time to time after that bio washing liquid
helps to keep it sweet
bill
