Refillable LPG (1 Viewer)
Jeroen van den Oever
21
24
Cambridge
Dethleffs A 7870-2
Newbie - caravanner since 2008
I’ve been reading about LPG tanks mounted between floors and are refillable to boot.
Had anyone got experience of those? Any issues with Eurotunnel? Refilling in Europe?
We've only used lightweight gas bottles - this option sounds cheaper and very convenient...
sedge
Jul 7, 2009
5,504
13,117
Nr Jct 3 M6
Aug 09 to date 9,000 miles!
Can't go on the tunnel with and LPG tank, whether it's for driving the vehicle or anything else. The refillable bottles are OK because they can be turned off in the usual manner and their capacity is pretty finite.
Bertie Bassett
2,743
8,702
since 1988
Where did that come from? Funsters (and some normal people) do it on a daily basis.
21
24
Cambridge
Dethleffs A 7870-2
Thanks all.
Found the Eurotunnel page too... Seems fixed tanks can only go to 80%... Bit of an issue if you’ve just refilled (and how do you accurately refil to 80% (n) Never mind releasing 20% from full :tmi:)
I think I’ll investigate Gaslow et al (y)
Plenty of LPG refilling availability in Europe by the looks of it (y)
Jan 28, 2008
10,117
18,383
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
all gas bottles have to be turned of in the tunnel underslung tank is just a bit harder to do advantage of an underslung tank is it frees up the gas locker space for more junk
Dec 24, 2009
1,072
15,721
bedworth warks
c class
2009 previously a tugger for thirty years
Don't want to hijack your threat but I have two full six kg cylinders here £125 for the pair if anyone's interested.
18,032
48,111
We have an underslung tank and after just over 5 weeks in Spain it is showing a little under half full although we only use it for cooking as the water heater is diesel /electric.
Other owners of our MH report no problems with the channel tunnel - they just ask you to turn off the tank using the valve at the tank outlet.
The system is very quick and easy to refill at garages with LPG and I have a gauge on the dashboard which tells me how much gas we have left which is a convenient feature.
However, retrofitting one is probably going to be more expensive than the gaslow system but it does free up storage space.
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Underslung LPG tanks are the definitely the way to go for convenience. With the tank plus 2 X 13 KG bottles we manage without buying local gas and all the problems that causes, ie, foreign regulators for even the longest trips of 6 months and more. If any van I have bought has not had a tank, its the first thing I have fitted. Many think that Gaslow refillable bottles do the same job, cheaper, but by the time you have bought all the paraphernalia to fit them correctly, there is little in it, with little gained if you only have a small gas locker. There have also been reports of some garages checking the system and refusing to allow the filling of refillable s.
Reactions: DBK
lorger
9,666
90,537
Dumfries
Knaus Sun 650MEG
We fitted the Autogas bottle and have to say its been great, we have managed to fill up in France and Norway with no issues.
21
24
Cambridge
Dethleffs A 7870-2
@Snowbird sounds like good advice.
@Techno100 Our motorhome-to-be has a double floor - can an "underslung" be put in between the floors?
Sounds like "underslung" is the way to go - I don't want hassles when refilling it, and I want to be able to Channel Tunnel it, so if there is a mechanism to fill up to 80% that would be fantastic.
I also like the idea of larger tanks so worry is taken out of any longer holidays we take abroad, and the freeing up of a cupboard :p
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
Underslung tank in my opinion has to be favourite for all the reasons given above ..... I would think yours would be fitted to the chassis beneath the floors but speak to Chris at http://www.autogasleisure.co.uk/.
He fitted ours and is very knowledgeable and helpful ... highly recommended and he gives a Funster discount.(y)
18,032
48,111
They don't fit between floors, they go underneath, probably bolted to a chassis member. I wouldn't want between floors even if it fitted, you want it outside the vehicle.
They don't have mechanisms to restrict filling to 80% but as already pointed out I don't believe that is a problem as you can't completely fill them anyway - I guess that is to allow room for expansion.
Might be worth contacting a manufacturer and asking for their opinion. All I can say is no one has had a problem that I am aware of.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Yes they do have 80% shut off
I'm concerned as to where some of you are getting your information?
18,032
48,111
I think we are talking about the same thing. When I fill mine at the pump the gauge says it's full but it isn't as you say. I suspect the internal fill pipe has a swan neck so to speak, not really a mechanism. I don't know, just guessing!
The problem, if there is one, is does the person at the Chunnel expect your gauge to show 80%? I don't think they do but experiences from others would be useful.
Feb 16, 2013
19,735
52,041
uttoxeter
ambulance conversion
50 years
I think we are talking about the same thing. When I fill mine at the pump the gauge says it's full but it isn't as you say. The problem, if there is one, is does the person at the Chunnel expect your gauge to show 80%? I don't think they do but experiences from others would be useful.
Why would the tunnel look at your gauge, they are only interested in whether it's off or on. Have gasit bottle with gauge , they have never looked at it yet.
Techno
Jul 28, 2010
15,475
20,756
May 2010
As I said my 60 litre tank will only tke 48 litres because it stops at 80% automatically .
All LPG tank for domestic use have 80% cut off
Oct 15, 2012
10,197
57,497
Market Harborough
C Class Laika Ecovip 7R
Have no knowledge off under slung tanks, I had 2x11kg autogas fitted to my van by Dave Newell ( with Funster discount )and am very happy with it, some will say you won't get your money back but it's worth it for the convenance, never had a problem filling them either. (y)
Techno
Jul 28, 2010
15,475
20,756
May 2010
Additionally I have never crawled under the van to isolate the tank. I simply turn off in the now redundant gas locker
