Refillable LPG
Discussion in 'Motorhome Chat' started by Jeroen van den Oever, Oct 26, 2014.
  1. Jeroen van den Oever
    Jeroen van den Oever Read Only Funster
    Oct 25, 2014
    21
    24
    Cambridge
    I’ve been reading about LPG tanks mounted between floors and are refillable to boot.
    Had anyone got experience of those? Any issues with Eurotunnel? Refilling in Europe?
    We've only used lightweight gas bottles - this option sounds cheaper and very convenient...
  2. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    Look for Gaslow threads.
  3. Bertie Bassett
    Bertie Bassett Read Only Funster
    Jul 25, 2014
    2,743
    8,716
    Most comprehensive and up to date availability of lpg throughout Europe Jeroen:-
    http://www.mylpg.eu/
  4. sedge
    sedge Funster
    Jul 7, 2009
    4,600
    4,140
    Nr Jct 3 M6
    Can't go on the tunnel with and LPG tank, whether it's for driving the vehicle or anything else. The refillable bottles are OK because they can be turned off in the usual manner and their capacity is pretty finite.
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    Sorry Sedge but you're completely wrong
    • Like it Like it x 1
  6. hilldweller
    Dec 5, 2008
    27,540
    26,626
    Macclesfield
  7. Techno
    Jul 28, 2010
    14,187
    15,162
  8. Bertie Bassett
    Jul 25, 2014
    2,743
    8,716
    Where did that come from? Funsters (and some normal people) do it on a daily basis.
  9. Bertie Bassett
    Jul 25, 2014
    2,743
    8,716
  10. Techno
    Jul 28, 2010
    14,187
    15,162
    Not between floors no but refered to as "underslung" as they are attached to the chassis
  11. Techno
    Jul 28, 2010
    14,187
    15,162
  12. Jeroen van den Oever
    Oct 25, 2014
    21
    24
    Cambridge
    Thanks all.
    Found the Eurotunnel page too... Seems fixed tanks can only go to 80%... Bit of an issue if you’ve just refilled (and how do you accurately refil to 80% (n) Never mind releasing 20% from full :tmi:)
    I think I’ll investigate Gaslow et al (y)
    Plenty of LPG refilling availability in Europe by the looks of it (y)
  13. Techno
    Jul 28, 2010
    14,187
    15,162
    All refillable bottles & tanks have built in 80% shut off.
    Example My 60 litre tank will shut off at 48 litres
  14. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,214
    3,629
    walthamstow east london
    all gas bottles have to be turned of in the tunnel underslung tank is just a bit harder to do advantage of an underslung tank is it frees up the gas locker space for more junk
  15. sedge
    sedge Funster
    Jul 7, 2009
    4,600
    4,140
    Nr Jct 3 M6
    Apologies! my mistake. Just if it's used to fuel the vehicle it's banned than.
    • Like it Like it x 2
  16. trophychap
    trophychap Funster
    Dec 24, 2009
    731
    5,738
    bedworth warks
    Don't want to hijack your threat but I have two full six kg cylinders here £125 for the pair if anyone's interested.
  17. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,946
    12,203
    Plympton, Devon
    We have an underslung tank and after just over 5 weeks in Spain it is showing a little under half full although we only use it for cooking as the water heater is diesel /electric.
    Other owners of our MH report no problems with the channel tunnel - they just ask you to turn off the tank using the valve at the tank outlet.
    The system is very quick and easy to refill at garages with LPG and I have a gauge on the dashboard which tells me how much gas we have left which is a convenient feature.
    However, retrofitting one is probably going to be more expensive than the gaslow system but it does free up storage space.
  18. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,286
    16,958
    Liverpool.
    Underslung LPG tanks are the definitely the way to go for convenience. With the tank plus 2 X 13 KG bottles we manage without buying local gas and all the problems that causes, ie, foreign regulators for even the longest trips of 6 months and more. If any van I have bought has not had a tank, its the first thing I have fitted. Many think that Gaslow refillable bottles do the same job, cheaper, but by the time you have bought all the paraphernalia to fit them correctly, there is little in it, with little gained if you only have a small gas locker. There have also been reports of some garages checking the system and refusing to allow the filling of refillable s.
  19. lorger
    lorger Funster
    Jul 11, 2008
    6,338
    7,791
    Dumfries
    We fitted the Autogas bottle and have to say its been great, we have managed to fill up in France and Norway with no issues.
  20. Jeroen van den Oever
    Oct 25, 2014
    21
    24
    Cambridge
    @Snowbird sounds like good advice.
    @Techno100 Our motorhome-to-be has a double floor - can an "underslung" be put in between the floors?
    Sounds like "underslung" is the way to go - I don't want hassles when refilling it, and I want to be able to Channel Tunnel it, so if there is a mechanism to fill up to 80% that would be fantastic.
    I also like the idea of larger tanks so worry is taken out of any longer holidays we take abroad, and the freeing up of a cupboard :p
