Oil Filled Heater (1 Viewer)
trevtherev
37
16
Suffolk
Newie but caravaned 30 years
Hi All, My 10 year old Autocruiser only has gas heating, As a bit of a tight bugger I dont want to be useing my gas when on elec. Hookup. We have a elec. fan heater but its to noisy to use overnight, then someone suggested a small oilfilled radiator. That sounds like the ideal solution. Something not to powerful or bulky and thermostatically controlled. Any recommendations please.
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
De-Longi do a good range...
We got a small one we leave on low in the winter, just enough to take the chill off and keep frost at bay...
Run our`s on number three, but do wack it up to 9 and after an hour it is hot inside.. (y)
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
We have a small 500 watt oil filled heater
It's not large enough to warm van when it's very cold but does keep of the chill at night
this morning when I woke it was a bit chilly so I put gas heating on for 10 minutes now it's nice and warm :)
Plus it's small enough to hide in a inside locker without taking up too much space (y)
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
As a by............. I have heard or read of some splitting and leaking..
So best if you can to stand it in some kind of tray to catch any leaking oil if possible.. should that happen.. (y)
Theonlysue
6,104
7,383
As Executive 50th an
Not long enough!
Is there some way he can curtain off the front cab area as when I do this, there is a noticeable difference in the hab area. I also gave used a small 500 watt oil rad, and it definitely helped.
paulmold
892
302
North Wales
7 year (25yrs a tugger)
Try Dunelm, Poundstretchers and Original Factory Shop, they all have them in the range of 500 to 700w. but Dunelm have them at 50% off at the moment, £9.99
And as a by by..... I did phone our insurers to ask if we were covered "you are not covered, this departs from the standard build which we assume when issuing cover, you can leave the built in heating on if you wish".
I leave a low wattage heater on all winter anyway, just to keep above freezing.
Cobweb
388
349
North Yorkshire
We also keep a small oil filled radiator in the van and leave it on a low setting overnight if it is cold and we are hooked up . Otherwise we leave the heating on low .
T
trevtherev
37
16
Suffolk
Took the plunge and ordered a 800 watt oil filled one off ebay. I would imagine that 99% of them are made in China now, buying products from recognised reputable manufacturers is no guarantee that it is not made in China nowdays. Thanks for the info.
May 29, 2013
2,598
19,244
Tyneside
Chausson best of Flash 10
Several years now
I have a 200W block heater, which I am going to attach to a plug in thermostat. 200W would keep the chill off in winter and also be good enough to keep the MH warm-ish overnight, unless your in the Artic. Depending on the size of your MH and it's insulation of course.
Obviously, it will have to stand on a non-flammable surface or have some legs on it.
May 29, 2013
2,598
19,244
Tyneside
Several years now
200w ! that's the warmth of a light bulb!
True, but it will keep an un-insulated, very large fibre-glass cabinet, above 10c whatever the outside temp.
Remember, over night in a MH, the bodies are also radiating heat, the amount depends upon the activities undertaken of course !
TERRY&PAULINE
116
107
coventry
autocruise starfire
since 1987
We have used 2 small oil filled heaters for years, one in the front and one in the rear, never had a problem, they are thermostatic, we wouldn't leave gas on all night, when not in use they fit behind the front seats, cheap on local e bay with Marin Lewis E-bay mapper,
2,338
10,132
@trevtherev
absolutely correct.. the emphasis should be on 'cheapo' .. rather than 'Chinese '
big names like De Longi, Honeywell and Dimplex are all probably made there now.
The one that caught fire in the link was aLink Removed(not 700kw as advertised in Amazon :rolleyes:) looks like it's discontinued ..
there was also a link to a recall in the US http://www.cpsc.gov/en/recalls/2007...l-filled-electric-heaters-due-to-fire-hazard/
My personal thoughts are that a small panel convector or greenhouse tubular heater is safer.. but nothing is 100% safe.. hence Brian's call to his insurer ..
I had two wall mounted ones in the RV to keep the chill off the toilet and one in the belly locker to stop the tanks and pipes freezing..
Belly locker with heater on wall ..
