- Feb 24, 2013
- 13,087
- 101,469
- Hymer S800
- not long enough
Morning, incoming query from man with zero technical skills
This is really odd, but I hope somebody else has had similar or recognises the symptoms
We have a sat dome and currently being parked up in Durness have really appreciated not having a standard dish which I would not have put up
The problem
I had noticed some signal problems, but presumed that was still down to the wind, until today
Put TV on in bed, the TVs are satellite only if it helps, perfect picture, came down to lounge end and put other TV on same channel, perfect picture, realised I had left bedroom TV on and turned off, immediately lost lounge picture with loss of signal. Turned bedroom back on lounge OK again
I have noticed that when sat in lounge when I lost signal I checked the sat input lead and when touching it improved or restored signal
So even I have realised the cable is the key, but what might be wrong with it? everything seems to be tight enough, anybody got anything simple I should try?
Leaving other TV on is not the end of the world, but there must be a better solution
The problem
