Odd problem with Sat TV's (1 Viewer)
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
Morning, incoming query from man with zero technical skills
This is really odd, but I hope somebody else has had similar or recognises the symptoms
We have a sat dome and currently being parked up in Durness have really appreciated not having a standard dish which I would not have put up
The problem
I had noticed some signal problems, but presumed that was still down to the wind, until today
Put TV on in bed, the TVs are satellite only if it helps, perfect picture, came down to lounge end and put other TV on same channel, perfect picture, realised I had left bedroom TV on and turned off, immediately lost lounge picture with loss of signal. Turned bedroom back on lounge OK again
I have noticed that when sat in lounge when I lost signal I checked the sat input lead and when touching it improved or restored signal
So even I have realised the cable is the key, but what might be wrong with it? everything seems to be tight enough, anybody got anything simple I should try?
Leaving other TV on is not the end of the world, but there must be a better solution
tonka
10,830
21,528
Cannock, Staffs
A class Burstner 800
Since 2000
The inner cable in the coax can easily "slide" . Causing a poor connection.
Especially with screw on F plugs.
Turn off power and re-do the "F" plug...
Try that first...
eddie
8,157
41,268
Taunton Somerset
RV
since 1989
What make dome do you have? and are you using a digi box? or is the sat reciever built into the TV?
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
Its a Maxview, with what I presume to be a separate box but part of the package marked up Maxview as well, we can have different programs on the TVs that was part of the set up so I guess it must be through a box
Sorry about idiot level of knowledge
Try that first...
I have done a bit of tightening up, but did it before reading about turning off power first!! survived though. Cable goes through a 90 degree connector, looked like the top entry fitting was loose I hadn't noticed that, I had only checked the bit going into the TV
eddie
8,157
41,268
Taunton Somerset
RV
since 1989
Quick realease and 90% connectors are the cause of "most" RF problems. Try removing the connector and try again
Daifuse
183
310
Milford Haven
c class
Since 2011
Try that first...
'F' plugs? I have my own idea what the F stands for - Effing! So I replaced all mine with F to BNC adapters. That solved some re-curring problems.
tonka
10,830
21,528
Cannock, Staffs
Since 2000
I used to love em...... £20 call out just to re-fit an "F" plug :) (y)
DavidG58
Feb 24, 2013
13,083
101,448
Hymer S800
not long enough
is there any logic though for why both TV's work correctly when both on, but the lounge one not on its own?
I do think it seems to be much improved since I tightened both ends of the 90 degree connector in the lounge
weekenders
2,658
1,967
Leicestershire
15 years
We have the maxview dome, we have received channels ok, last used Valentine weekend, tried using it in Dorset last weekend, and it took a while to search, then got some channels.
It worked Saturday sfternoon, but could not receive any channels Saturday night, we were on Astra 28e.
Is there anything we could try to receive channels again, any help appreciated
