Not mounting a solar panel...
Discussion in 'Solar Power' started by Bacchus, Apr 24, 2016.
  1. Bacchus
    Bacchus Banned 1 month
    Jul 27, 2015
    423
    4,286
    Staines
    Does anyone have any opinions on having a "roving" solar panel?
    I generally use my van for touring, I don't stay anywhere (without EHU) for more than a couple of days so the leisure battery gets enough from the engine to keep me going, but I was thinking of getting a solar panel which I can carry in the van so if I do stop somewhere for a little bit longer I can whip it out and put it in the sunniest place, maybe mounted on a cheap overbed table like this to get the best angle:-
    [​IMG]
    Apart from the ease with which it could be stolen, are there any practical reasons why this is a bad idea?
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,688
    5,837
    Mansfield,Notts
    Me thinks you have just Re Invented the wheel
    As dear or as cheap as you like
  3. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,435
    7,724
    1. You will need to sit by it or chain it up for security.
    2. If you want optimum from it you will need to get up and keep moving to follow the sun..
    3.. Just stick one on the roof and be done with it :) While your lying in bed early morning it will be charging, while your out for the day it will be charging, while the van is parked up and not being used it charging.... You know it makes sense.
    ps.. 4.. You dont need any space inside to keep it.
    • Like Like x 5
  4. Flamenca
    Flamenca Funster Life Member
    Jun 21, 2013
    763
    460
    Cornwall/France/Spain
    I have been using three 20W panels on the fascia of my Hymer which have performed quite well. I am about to mount two 80W panels on the roof for more output and less clutter in the cab.
    • Like Like x 1
  5. glenn2926
    glenn2926 Funster
    Sep 11, 2012
    334
    515
    Gods country
    I have been following the various threads re solar panels. I am thinking of fitting one but I really do not want to drill any holes in the van. There are enough threads about damp without giving the water anymore ways into the van. Are there any ways of fitting without making holes in the van? Holes for fixing and for cables.
  6. Bacchus
    Jul 27, 2015
    423
    4,286
    Staines
    Ah... yes... but... I was thinking of using the panel that is lurking in my garage... (c;
    My thinking is that the van spends most of its time either touring or sitting on the drive without any need for juice (old van with nothing complicated going on), I also have a small boat which does need a small amount of juice to run the bilge pump every time it rains so the panel could spend most of its working life looking after the boat and then come away for the occasional holiday :).
    If I mount it on the van it will spend up to ten months of the year generating unwanted electricity and gathering poop so it needs a clean when I do want it, and I will need to buy another one for the boat.
  7. Geo
    Jul 29, 2007
    9,688
    5,837
    Mansfield,Notts
    Then your Idea is sound,(y) why not.
    I would suggest a very simple leg arrangement as used on many commercial units
    But you probably have another garage full of old Hospital beds with meal tray mounts :LOL:
    Geo
    • Like Like x 1
    • Funny Funny x 1
  8. tonka
    Jul 2, 2008
    5,435
    7,724
    Well i think you have already made up your mind on what to do. All good reasons.. (y)
    • Thanks Thanks x 1
  9. Bacchus
    Jul 27, 2015
    423
    4,286
    Staines
    Certainly got a few bits in my garage! I thought that I'd chucked most if it away after the 2014 floods but it seems to accumulate...
  10. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,060
    485
    http://www.motorhomefun.co.uk/forum/threads/solar-panel-fitting.110122/
    • Useful Useful x 1
  11. glenn2926
    glenn2926 Funster
    Sep 11, 2012
    334
    515
    Gods country
  12. Geo
    Jul 29, 2007
    9,688
    5,837
    Mansfield,Notts
    I'm sure you already have 3 or 4 very large holes in your roof covered by skylights two or so more for vents/ arial etc so one more for a cable wont harm at all
    In short no real alternative to a cable gland and even if you made the worst bodge job of it in the world, it can be rectified in 5 minuets so its no biggy.
    make the smallest pencil sized hole possible followed by squirting in some sikaflex into the hole, followed by a water proof cable gland over the top with sikaflex inside, and a large dollop outside making sure the gland faces backward and all edges are covered seemples
    I fully understand your concern and surmise you aren't an ex submariner:LOL:
  13. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,393
    2,440
    Tunbridge Wells
    If you have rooflights you already have holes in your roof! One more one that is probably only 20mm diameter won't make a lot of difference. Done properly there will be no problems with leaks.
  14. glenn2926
    glenn2926 Funster
    Sep 11, 2012
    334
    515
    Gods country
    Thanks all, I will look into this soon.
  15. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,060
    485
    I used one of these, smallish hole drilled from roof into a cupboard and stuck with sikaflex. C5482.jpg
  16. Khizzie
    Khizzie Funster
    Jul 26, 2014
    2,371
    3,632
    Newbury , West Berkshire
    Chinese ones are cheaper .haha..
