Solar Panel Fitting
Discussion in 'Solar Power' started by IanF, Jun 9, 2015.
  1. IanF
    IanF Funster
    May 7, 2013
    2,196
    645
    Redcar- N.Yorkshire
    No doubt this question will have been asked before but unfortunately I can't find the answer by searching on here. I know how to fix the mounts to the roof of the MH using Sikaflex but
    how do you fit the plastic mounting kits to the solar panels?
    I look forward to your kind guidance
    Thanks again
    Ian
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,138
    15,084
    Leeds the one up North
    Self drilling screws, self tappers or drill and tap.
    On mine they had no holes drilled so I drilled them 5mm and presented bracket to the frame and drilled through again 5mm. I then tapped the holes in the frame 6mm and drilled out the holes in the brackets to 6.5mm
  3. IanF
    IanF Funster
    May 7, 2013
    2,196
    645
    Redcar- N.Yorkshire
    Thank you Techno100 -what size of bolts would you recommend?
  4. Techno
    Jul 28, 2010
    14,138
    15,084
    As edit above.
    I later ordered button headed socket screws
    [​IMG]
    [​IMG]
  5. Techno
    Jul 28, 2010
    14,138
    15,084
    Self drilling roofing screws from any good ironmongers probably most commonly used.
    Don't be bamboozled by the dissimilar metal brigade, it would take far too many years for corrosion to be an issue.
    [​IMG]
  6. IanF
    IanF Funster
    May 7, 2013
    2,196
    645
    Redcar- N.Yorkshire
    Thanks again Techno100 your advice is excellent as usual and very much appreciated
    Ian
    • Like Like x 1
  7. Techno
    Jul 28, 2010
    14,138
    15,084
    Anytime Ian. I've requested topic move to Solar section (y)
    EDIT which has happened already as if by magic :cool:
    • Like Like x 1
  8. josephmay842
    josephmay842 Read Only Funster
    Oct 28, 2015
    united states
    That's really great screws for the panel. Great solution on adding those panels to roof.
  9. UK Pete
    UK Pete Read Only Funster
    Jan 16, 2014
    285
    334
    kent
    I have sikaflexed mine to the roof, the area where your sticking to has to be prepared well this stuff will really stick them on good, but for peace of mind you could stick and put a small self tapper
    whopps just re read and i though you were talking about sticking to the van roof
  10. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,608
    1,670
    Stretford
    The only downside of sticking direct to the roof, if the Solar panels fail and need replacing could be a nightmare
  11. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,060
    6,062
    West Sussex
    Can't agree on that one, screw S/S self tappers into aluminum, and the aluminum will corrode around the holes within a few years. Even worse where I live a cople of hundreds of yards from the beach in a nice salty atmosphere which accelerates the process. When using S/S nuts & bolts on aluminum I always smear the aluminum with Evo Stick or Silicon an old yatchmans trick.
  12. BONZO
    BONZO Funster
    Mar 1, 2012
    275
    180
    Rotherham
    Can two panels be wired together or do each have to have there own controler? As I'm thinking of getting another one . And iv I do should I get the same ie iv got 80w fitted so could I put say 100w with it . John
  13. OldAgeTravellers
    OldAgeTravellers Funster Life Member
    Jan 6, 2014
    358
    229
    Languedoc, France
    Hi Andy, @Techno100 I notice you used the plastic brackets here (above) which seem quite expensive but in later posts elsewhere you are using ally angle. Which is your preference? Two of my 100 watt new panels (which will hopefully arrive today :) ) will be side to side rather than long side in direction of travel like above, to fit the space would you use three brackets a side?
    You have also shown on other posts that you use the Sikaflex cleaner activator, here in France I just can't find it and the carriage from the UK would be far too high. Do you think a bit of abrasion with fine wet and dry then a good clean, finishing with clean Meths would be good enough? Or do you think that there is actually a chemical reaction with the Sikoflex. How much Sikoflex would I need for three panels so say 18 brackets. Anybody used Sikoflex without the activator? I certainly don't want to see my panels sticking out of the following vehicles windscreen. :(
    Steve
  14. Allanm
    Allanm Funster
    Jun 30, 2013
    3,139
    4,281
    Cotes d'armor, France
    I sikaflexed the brackets to the roof after I had pop riveted the panel to the brackets. Aluminium panel surrounds and aluminium rivets = no corrosion.
    I cleaned the roof first with meths, didn't see any reason to use activator.
  15. Techno
    Jul 28, 2010
    14,138
    15,084
    Angle.
    Four of the plastic ones were already on my van when I bought it.
    [​IMG]
    [​IMG]
    [​IMG]
  16. OldAgeTravellers
    Jan 6, 2014
    358
    229
    Languedoc, France
    Hi Andy @Techno100 ,
    I see you have shared brackets in that last photo, did you bolt the panels together? As I am fitting two 100watts side by side I was thinking of bolting them together and sharing the centre bracket.
    Is that some white plastic angle blocking the wind to reduce the lifting effect in the last photo?
    Steve
  17. Peter A Forbes
    Peter A Forbes Funster
    Nov 23, 2014
    262
    182
    Rushden, Northants, UK
    We have had stainless bolts and screws into extrusions on the trailer build, no signs of any dissimilar corrosion, body or solar panels.
    Same on the panels on the Mercedes:
    [​IMG]
    [​IMG]
    Peter
    • Like Like x 1
  18. Techno
    Jul 28, 2010
    14,138
    15,084
    No they don't share and it's a strip of plastic flat bar
    [​IMG]
    • Like Like x 1
  19. Techno
    Jul 28, 2010
    14,138
    15,084
    Likewise on my own having recently lifted them for a roof scrub there is zero corrosion and I fitted them Feb 2013
  20. Techno
    Jul 28, 2010
    14,138
    15,084
    In some circumstances you can integrate the entry gland. This was forced upon me by space restrictions but worked well
    [​IMG]
    [​IMG]
    • Like Like x 1
