NASA BM-1 Battery Monitor (2 Viewers)
pablomc
772
237
Durham
Need to buy a BM-2 (as I now have a 2.5KW inverter :Eeek:), so selling the BM-1 I have (never installed or used). Offering here before I put on ebay. ::bigsmile:
For anyone who does not know the difference, the BM-1 is rated up to 100 ams and the BM-2 to 200amps.
G8WVW
92
67
Cumbria
Since 1990 on/off
BM1 excellent. Have one myself.
2.5KVA inverter; crikey!
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
my existing Solar regulator shows charge rate, discharge rate and battery Voltage or % charge what is the differance please.
MicknPat
614
3,606
Touring UK
39ft American A class RV
Since Oct 2007
Simply, what does the BM-2 do that the BM-1 doesn't?
I have a BM-1 still in its box waiting for good weather and someone ( one of my sons) to crawl under the RV to route and secure the wiring between the batteries and the BM-1 monitor. :Smile:
11,932
9,097
ÂŁ100 ish ::bigsmile:
But the blurb says it can handle from 5 to 650 amps :Smile:What on earth are you running to want 2.5kw--must be overkill :Eeek:::bigsmile:
terry
MicknPat
614
3,606
Touring UK
Since Oct 2007
Sorry about that Pablomc, I'm no electrician nor do I fully read the postings. :Sad:
So have I goofed in buying a BM-1 to connect to the 4x 6 volt 232 Amp hour house batteries that are connected in series so giving (if I understand it correctly) 12 volt 464 AH?
Thanks :thumb:
pablomc
pablomc
772
237
Durham
Thanks :thumb:
Nope overall rating does not matter, it's if you intend to pull a high current in excess of 100 Amps from them.
So if you only ever pull say 20 amps max then no biggy, but if you have an inverter then there is potential to draw a lot more depending on the inverter size. E.g. when I tested mine with the wife's hair dryer it was pulling 165amps :Eeek:.
If you don't have an inverter, then don't worry the BM-1 will be more than adequate. ::bigsmile:
pablomc
pablomc
772
237
Durham
Thanks :thumb:
BTW if you have 4 X 6 volt batteries then they should be wired as pairs in series then those two pairs in parallel for 12 volts. If you wire them all in series you will have 24 volts and if all in parallel 6 volts. If in doubt ask. :thumb:
pablomc
pablomc
772
237
Durham
terry
See the previous post re the rating. :thumb:
Re the 2.5 better to have too much than too little. :Tongue1: :roflmto:
43,337
49,538
only drawback with a large inverter, it will use more power when idle...ie: on standby with nowt plugged in... than a litte 'un so really needs turning off completely when not in use.
MicknPat
614
3,606
Touring UK
Since Oct 2007
Looking at the pdf schematic from Fleetwood for our RV the connections go like this.
Battery 1. + to battery 3 + inverter etc
- to battery 2 +
Battery 2. + to battery 1 -
- to battery 4 -
Battery 3. + to battery 1+
- to battery 4+
Battery 4. + to battery 3-
- to battery 2- and ground
Doesn't those connections make is part serial part parallel ? All Greek to me :Smile:
thanks :thumb:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The bigger Sterlings come with remote switch to place where convenient.My inverter is in the garage
pablomc
pablomc
772
237
Durham
0.4A in power save mode and 1.8 A in on mode, or as described by Techno100 can be switched off at the remote panel. :Smile:
jb0371old
465
408
Autotrail
1 year
If its still for sale can I have first dibs on it, away in the van till tomorrow so internet a bit touch and go at the minute
pablomc
pablomc
772
237
Durham
Was going to put it on ebay at the weekend if there were no takers, but will hold off until you are back on line, so you can certainly have first shout. :thumb:
43,337
49,538
thats what i mean.....doesnt sound a lot but added up it is a lot.
0.4amp over 24hrs = 9.6amps
1.8amp over 24hrs = 43.2amps
turned off completely, either remotely or manually = 0.0 amps
That's your average MH battery flattened in 24hrs and the inverter has done sweet FA work.
Mind you, same average battery wouldn't last 10 mins with that thing really working. Lifespan of battery wouldn't be long I would think.
pablomc
pablomc
772
237
Durham
I don't have "average" motorhome batteries and the inverter is off when not required. :winky:
