NASA BM-1 Battery Monitor
Discussion in 'Motorhome Chat' started by pablomc, Feb 17, 2013.
  1. pablomc
    pablomc Funster Life Member
    Apr 20, 2010
    860
    235
    Durham
    Need to buy a BM-2 (as I now have a 2.5KW inverter :Eeek:), so selling the BM-1 I have (never installed or used). Offering here before I put on ebay. :BigGrin:
    For anyone who does not know the difference, the BM-1 is rated up to 100 ams and the BM-2 to 200amps.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,718
    17,332
    YO11 2BD
    asking price ?
  3. pablomc
    Apr 20, 2010
    860
    235
    Durham
    Thinking £85 including P&P.
  4. G8WVW
    G8WVW Read Only Funster
    Jan 15, 2013
    92
    66
    Cumbria
    BM1 excellent. Have one myself.
    2.5KVA inverter; crikey!
  5. manda3000gt
    manda3000gt Funster
    May 6, 2010
    427
    552
    Doncaster
    Did you buy a Sterling inverter ? Pure sine or modified ?
  6. pablomc
    Apr 20, 2010
    860
    235
    Durham
    Yes Sterling procombi pure sine wave. Got it off ebay. :Smile:
  7. manda3000gt
    manda3000gt Funster
    May 6, 2010
    427
    552
    Doncaster
  8. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    my existing Solar regulator shows charge rate, discharge rate and battery Voltage or % charge what is the differance please.
  9. MicknPat
    MicknPat Funster
    Dec 16, 2007
    628
    2,967
    Touring UK
    Simply, what does the BM-2 do that the BM-1 doesn't?
    I have a BM-1 still in its box waiting for good weather and someone ( one of my sons) to crawl under the RV to route and secure the wiring between the batteries and the BM-1 monitor. :Smile:
  10. pablomc
    Apr 20, 2010
    860
    235
    Durham
    :thumb:
  11. Terry
    Terry Funster
    Dec 27, 2007
    10,739
    6,240
    South yorks
    £100 ish :BigGrin:
    But the blurb says it can handle from 5 to 650 amps :Smile:What on earth are you running to want 2.5kw--must be overkill :Eeek::BigGrin:
    terry
  12. MicknPat
    MicknPat Funster
    Dec 16, 2007
    628
    2,967
    Touring UK
    Sorry about that Pablomc, I'm no electrician nor do I fully read the postings. :Sad:
    So have I goofed in buying a BM-1 to connect to the 4x 6 volt 232 Amp hour house batteries that are connected in series so giving (if I understand it correctly) 12 volt 464 AH?
    Thanks :thumb:
  13. pablomc
    Apr 20, 2010
    860
    235
    Durham
    Nope overall rating does not matter, it's if you intend to pull a high current in excess of 100 Amps from them.
    So if you only ever pull say 20 amps max then no biggy, but if you have an inverter then there is potential to draw a lot more depending on the inverter size. E.g. when I tested mine with the wife's hair dryer it was pulling 165amps :Eeek:.
    If you don't have an inverter, then don't worry the BM-1 will be more than adequate. :BigGrin:
  14. pablomc
    Apr 20, 2010
    860
    235
    Durham
    BTW if you have 4 X 6 volt batteries then they should be wired as pairs in series then those two pairs in parallel for 12 volts. If you wire them all in series you will have 24 volts and if all in parallel 6 volts. If in doubt ask. :thumb:
  15. pablomc
    Apr 20, 2010
    860
    235
    Durham
    See the previous post re the rating. :thumb:
    Re the 2.5 better to have too much than too little. :Tongue1: :Laughing:
  16. pappajohn
    Aug 26, 2007
    29,718
    17,332
    YO11 2BD
    only drawback with a large inverter, it will use more power when idle...ie: on standby with nowt plugged in... than a litte 'un so really needs turning off completely when not in use.
  17. MicknPat
    MicknPat Funster
    Dec 16, 2007
    628
    2,967
    Touring UK
    Looking at the pdf schematic from Fleetwood for our RV the connections go like this.
    Battery 1. + to battery 3 + inverter etc
    - to battery 2 +
    Battery 2. + to battery 1 -
    - to battery 4 -
    Battery 3. + to battery 1+
    - to battery 4+
    Battery 4. + to battery 3-
    - to battery 2- and ground
    Doesn't those connections make is part serial part parallel ? All Greek to me :Smile:
    thanks :thumb:
    • Like Like x 1
  18. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,108
    14,922
    Leeds the one up North
    The bigger Sterlings come with remote switch to place where convenient.My inverter is in the garage
    [​IMG]
    • Like Like x 1
  19. pablomc
    Apr 20, 2010
    860
    235
    Durham
    0.4A in power save mode and 1.8 A in on mode, or as described by Techno100 can be switched off at the remote panel. :Smile:
  20. jb0371
    jb0371 Funster
    Jul 8, 2011
    462
    402
    Norfolk
    If its still for sale can I have first dibs on it, away in the van till tomorrow so internet a bit touch and go at the minute
