LED Problem (3 Viewers)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Heres one to tax you eggheads. In our Hymer bathroom, there is a strip four bulb holder mounted vertically next to the sink.
And so, I decided in the interests of power saving and increased light, to replace the bulbs with four of these LEDs..........(12 volt, 5 watt)
But they wont work! Tried them in the sidelights, they work. In the overbed spotlights, fine, but not in the bathroom, either together, or just as a single. Reversed the polarity, nothing........Cant understand it. The standard filament bulbs in the unit are rated at 12 volt 5 watt each.......Any ideas??
18,035
48,140
Have you fused anything? Check by putting one of the old bulbs in and see if it glows in a bulby sort of way.
Also try covering the mirror. Your reflection may the problem. :)
DuxDeluxe
14,659
72,805
Planet Zog
A woosh bang van
Tootles doesn't have a reflection when in front of the mirror........ ;)
18,035
48,140
On a more serious note put the two different bulbs next to each other and check the dimensions and contacts are identical.
We've got a fancy bathroom light which needed a new fluorescent tube. Could I get one the right size locally? Had to get it online. Your make-up lights might be something odd. Close to a standard bulb but subtly different for maximum bu**eration factor. Probably Italian like our bathroom light. :)
DuxDeluxe
14,659
72,805
Planet Zog
A woosh bang van
That is distressingly sensible advice.............:LOL:
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Everything is identical to the standard filament bulbs. Tested the output from each bulb holder, all the same. I'm starting to wonder if this light unit, (the only power into the bathroom), is somehow controlled by a resistor unit that is not compatible to LEDs. ??????
43,334
49,533
If the led's are rated at 5 watts and the original filiment bulbs are rated at 5 watts.....what do you hope to gain ?
5 watts is 5 watts.
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
5 watts is 5 watts.
The 5 watts refers to the light output John. LED's use a smaller proportion of power then filament bulbs, because there's nothing to heat up. And so I would be getting the same amount of light for less power used.
43,334
49,533
Ok, that clears that up.
I thought you meant input watts.
A 12v 5watt led is equivilent to around 40 watts.
I cant see any reason for the circuit to include a resistor.....thats generally reserved for led road lighting with a canbus bulb failure system so the system still sees a regular bulbs resistance thus not thinking a bulb has failed.
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Are they transformer operated toots, do they work without being on EHU
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Yes mate, they do. I cant think of rhyme or reason for them not working.
34127
Have you tried putting back the original bulbs and then swapping just one of them for the LED type. It may be that you have a control circuit (could be a dimmer or some sort of voltage control) that needs a minimum current drawn from it to make it work and the LED current requirements may be below this.
Hymie
810
1,005
Classic Hymer B564
Since 1981
Toots, where did you get the led lamps from?
We have the same bathroom as you, bottom lamp is almost dead now so was thinking of changing them to LED's.
If I can buy some the same I will try them in ours and see what happens
Sep 10, 2012
2,133
3,714
worcester
Sunliving van
you need a bit of trial and error testing mate.
put all originals back in - take 1 out and replace with (previously tested) led.
if ok and lights continue with next and so on.
if not working with even 1 led and 7 filament you will have to get to the wiring behind the fitting and see how its all connected up (yes i know pain in the arse)
how about putting a strip of self adhesive led down each side inside the fitting and connecting directly to the switch supply.
not had a similar problem myself but hope that gives u food for thought.
bern
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Is there a dimmer on this circuit? Some LEDs don't like them.
No dimmer, but a hell of a sized switch for the job, which makes me think it may 'contain' some other circuit 'nasty'.......
Yes, tried all that. The filament bulbs will work, but the LED alongside will not.
Got them off ebay. Just input 12volt 5 watt LED vehicle bulbs. (y) (Sorry, I cant get ebay up at the mo).
bern
Thanks Bern. My next job will be to take a feed from before the switch, and see if lights an LED. If so, the (huge) switch must either have a resistor fitted, or some other voltage stabilizing device. (y)
34127
It seems as if the bulbs aren't making contact with the holders. Are the solder pips at the bottom of the bulb as prominent as the bulbs you are replacing. I once had a problem when replacing the bulb on some ophthalmic equipment and after messing around for quite a while I found out the bulbs were fractionally shorter and not making contact. I re-soldered the bottom of the bulb to build up the depth and that sorted the problem. It could be that the bulb holders are slightly different to others in your vehicle and that is why they work in some places and not others.
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
LED's wont work if + & - are reversed
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Tried that as well........And funny, neither did the original filament bulbs, which quite surprised me! Something in the circuit I'm missing.
43,334
49,533
You really do have a problem if the standard bulbs didnt work either.
A bulb will work no matter which way its connected.
Remember the old beetles with POSITIVE earth 6v systems
Tootles
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
I know John. With the wiring in the original position, the standard bulbs worked, but not the LED's However, when I reversed them, neither worked. Got to be a resistor somewhere.
Badknee
7,408
412,998
notloB
Vantage Neo
Living the dream.
Pfft, it's @Tootles Hymenwagen. Due to it being around since Adam was a lad it's refusing point blank to be dragged kicking and screaming into the 21st century. LED's? it's gas mantles more like. ;)(y)
Luv ya Dave :love:
Badknee
7,408
412,998
notloB
Vantage Neo
Living the dream.
You must understand that Badknee also has a gas telly. (y) And a towngas one at that. :)
Well of course we do, a forward thinking modern town like notloB has had town gas for years not like that tiny backwater that you live in. Acetylene gas is the best you can do. I'll tell you what, I'll bring you a bag of gas over as I have one on my roof rack. (y)
