He's got a short cuicuit but we knew that all along.I always knew you were wired wrong @Tootles
He's got a short skirt, tooHe's got a short cuicuit but we knew that all along.
Gas problem??I'll get my car fixed when we get back after Easter
Dawn, this is a LED bulb problem thread, and not a fat lady bulbous problem thread.I always knew you were wired wrong @Tootles
You mean that there are two motorhomes with a bathroom looking like a pimps boudoir?Toots, where did you get the red lamps from?
We have the same bathroom as you, bottom lamp is almost dead now so was thinking of changing them to LED's.
If I can buy some the same I will try them in ours and see what happens
And......?Dawn, this is a LED bulb problem thread, and not a fat lady bulbous problem thread.
Ali says your dead for calling her a pimp.You mean that there are two motorhomes with a bathroom looking like a pimps boudoir?
YayAli says your dead for calling her a pimp.
And, maybe you should watch this??
Don't worry, you wont turn black!!Nah, these things never end well
You think?? Ask her, I own nowt.Your bathroom.........
Pity...Don't worry, you wont turn black!!
Nothing would prevent filament bulbs working either way round.....if they work one way they WILL work the other.....unless the standard bulbs have a diode built in, which I have never seen as tjeres no point.I know John. With the wiring in the original position, the standard bulbs worked, but not the LED's However, when I reversed them, neither worked. Got to be a resistor somewhere.
No bulb diode's. And the stranded bulbs will not work with the polarity reversed.Nothing would prevent filament bulbs working either way round.....if they work one way they WILL work the other.....unless the standard bulbs have a diode built in, which I have never seen as tjeres no point.
The + & - feed wires only go to each end of another wire....the one inside the bulb.
Yes Colin, got me stumped as well. Here's what I did, from the beginning......Intriguing!
A filament lamp is basically a resistor, no polarity. The only thing that I can think of that would affect the circuit is some sort of controller somewhere in the feed wiring (possibly switch or light fitting), but that still shouldn't affect the filament lamps. As for the LEDs, they 'could' be affected by some control circuitry in the feed.
I agree with you that the next best step is to provide an alternative feed from before the switch which you have already proven to be good for LEDs to bypass the switch, if they still don't work I would suspect either the fitting or some other control circuitry.
Really don't understand why the lamps won't work t'other way around!
Cheers Paul, but I have to find out WHY Hymer would fit such a switch. Is it to protect something? Maybe some German construction ruling about electricity and bathrooms? Trawled the web, but nothing. A phone call to Brownhills in the morning, I think.Ah, I think you have it there. As said filament bulbs will not be effected by reversing the + - as it's just a piece of wire getting hot but yours were so it has to be the switch.
The switch still doesnt explain why the filament bulbs dont work with neg center post.Ah, I think you have it there. As said filament bulbs will not be effected by reversing the + - as it's just a piece of wire getting hot but yours were so it has to be the switch.
Makes sense, but why fit a diode when filament bulbs are polarity sensitive.or a diode in the switch? that way you cant reverse the polarity
the switch may be a multi use one, not just used in motorhomes but also in controlled environments where the chassis of the light must not go liveMakes sense, but why fit a diode when filament bulbs are polarity sensitive.
