Laptop fan continuous running (2 Viewers)
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
My laptop has started running the fan at a high speed for long periods.
Anyone know what would cause it to do this?
Clive
1,296
1,782
Canvey Island
The cooling fins are blocked. Buy a tin of compressed air, turn the laptop of and give it a blast through where the hot air comes out (y) Cost me £50 to find this out :cry:
53,473
150,176
Processor getting too hot, could be a build up of dust & fluff in the case vents or on the processor heat sink.
MattR
4,105
38,952
Beds
Panel van
Years
How old is the machine and how much do you have running simultaneously? As above, blocked vents are the most likely cause but your computer may also be struggling with the amount of applications running at the same time and / or the machine is old and the cooling paste between the processor and motherboard needs replacing.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Make sure it's sitting on a flat, solid surface rather than a settee cushion or whatever, so it can ventilate itself. I agree with the other comments about giving the vents a clear out.
Something else that makes the fan noisy is if the blades go off centre due to wear on the bearing. A small piece of well-placed blu-tack on one of the blades can sometimes solve this.
keith
keith
3,421
1,864
Ecclefechan
Thanks I'll try that
Thanks again for that
No not old 2/3 years I don't run lots of programms at once, try the fluff removal first.
Is it a Dell by any chance ?
No Jim
Always on clear firm surface
Thanks for all replies I will try the dust removal forst.
2,337
10,146
ok.. I asked because I have a Dell Inspiron with an i7 processor that has overheated since day one.. been back to Dell TWICE and and still the same.. despite using a fan assisted cool pad, the internal fan runs all the time..
to clean it properly you may have to remove the back cover to gain access to clean the fan and processor heat sink.. I use a soft artists brush to clean delicate parts .
Dec 12, 2010
5,414
21,592
Cumbria
We took our pc in to a local shop for a repair a couple of years back. Missus went back to the shop a couple of days later and said "you phoned to say my computer was fixed"
The guy asks "is it a Dell ?" Wife says "no, it's Val" she was as red as a beetroot when she got back to the car :LOL:
keith
keith
3,421
1,864
Ecclefechan
My fan does run all the time Jim but very quietly so you cannot hear it. This sounds like a small concord taking off when it feels like it.
I cannot chance taking the back cover off as we are away in the van so it will have to wait until we get home. Have cleaned out what I can (not much) and so far it seems better. Fingers crossed.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I had similar issue with a Medion laptop. Cleaning helped, I used the air comp for my R-V tyres! with the pressure reg turned right down!. Bought a laptop stand with a USB fan in it, that had 2 benefits in that the computer fan ran far less often and the typing and viewing angle could be adjusted. the "stand" fan was not too noisy when in use and was not needed as often I think because the computer had more air space underneath it?. It is essential IMHO to always have the laptop on a hard surface to allow maximum air flow.
The new(er) Dell is better and that fan never runs (in fact I have never yet heard it!!)
Photo4x4
371
873
Scottish Highlands
Coachbuilt with over cab
Agree with all above, and certainly don't sit with your 'laptop' on your 'lap' for too long as it blocks the cooling vents. Why call them laptops!? :)
Here is one of the cooling pads: Broken Link Removed
I had a laptop that would overheat on my desk and one of those cured it.
Current laptop is fine - Packard Bell.
Keith Hart
Easyliving
956
2,021
Since 2011
My desktop pc fan was very noisy right from day one. Looking on forums I found that if you go into your bios settings (press 'del' as computer fires up if I remember rightly) there is a setting there that allows you to vary the speed and therefore noise of the fan. Sorry this is so vague but I am at work at the moment so can't verify with my pc but I found the relevant setting okay.
Paul
keith
keith
3,421
1,864
Ecclefechan
All seems to be running well now after a good blow out. I did also cleaned the system, via ASC, and a scan for viruses and malware.
2,337
10,146
Paul
This will be ok with a desk top.. they have plenty of cooling.. but
I would caution against adjusting the fan speed in the bios settings in a laptop..
it will reduce noise, but also reduce the cooling and consequently increase the processor core temperature...
in my case, it is overheating, not noise that is the issue.. the fan in my Dell runs flat out and it still overheats after an hour or so of heavy use..
My desk top PC fans seldom run.. and the 13" MacBook Pro never hear it .. and it runs as cool as a cucumber.
