Laptop fan continuous running
Discussion in 'Computers' started by keith, Feb 4, 2015.
  1. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    My laptop has started running the fan at a high speed for long periods.
    Anyone know what would cause it to do this?
  2. Clive
    Clive Funster Life Member
    Apr 30, 2012
    842
    1,237
    Canvey Island
    The cooling fins are blocked. Buy a tin of compressed air, turn the laptop of and give it a blast through where the hot air comes out (y) Cost me £50 to find this out :cry:
    • Like it Like it x 1
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    7,214
    7,078
    West Sussex
    Processor getting too hot, could be a build up of dust & fluff in the case vents or on the processor heat sink.
  4. Mattyjwr
    Mattyjwr Funster Life Member
    Aug 18, 2013
    1,945
    3,456
    Beds
    How old is the machine and how much do you have running simultaneously? As above, blocked vents are the most likely cause but your computer may also be struggling with the amount of applications running at the same time and / or the machine is old and the cooling paste between the processor and motherboard needs replacing.
  5. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    Is it a Dell by any chance ?
  6. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    4,023
    9,252
    NW England
    Make sure it's sitting on a flat, solid surface rather than a settee cushion or whatever, so it can ventilate itself. I agree with the other comments about giving the vents a clear out.
    Something else that makes the fan noisy is if the blades go off centre due to wear on the bearing. A small piece of well-placed blu-tack on one of the blades can sometimes solve this.
  7. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    Thanks I'll try that
    Thanks again for that
    No not old 2/3 years I don't run lots of programms at once, try the fluff removal first.
    No Jim
    Thanks for all replies I will try the dust removal forst.
  8. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    ok.. I asked because I have a Dell Inspiron with an i7 processor that has overheated since day one.. been back to Dell TWICE and and still the same.. despite using a fan assisted cool pad, the internal fan runs all the time..
    to clean it properly you may have to remove the back cover to gain access to clean the fan and processor heat sink.. I use a soft artists brush to clean delicate parts .
  9. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,825
    3,485
    Cumbria
    We took our pc in to a local shop for a repair a couple of years back. Missus went back to the shop a couple of days later and said "you phoned to say my computer was fixed"
    The guy asks "is it a Dell ?" Wife says "no, it's Val" she was as red as a beetroot when she got back to the car :LOL:
    • Like it Like it x 9
  10. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    My fan does run all the time Jim but very quietly so you cannot hear it. This sounds like a small concord taking off when it feels like it.
    I cannot chance taking the back cover off as we are away in the van so it will have to wait until we get home. Have cleaned out what I can (not much) and so far it seems better. Fingers crossed.
  11. PeteH
    PeteH Funster
    Nov 22, 2007
    2,308
    2,810
    East Yorkshire
    I had similar issue with a Medion laptop. Cleaning helped, I used the air comp for my R-V tyres! with the pressure reg turned right down!. Bought a laptop stand with a USB fan in it, that had 2 benefits in that the computer fan ran far less often and the typing and viewing angle could be adjusted. the "stand" fan was not too noisy when in use and was not needed as often I think because the computer had more air space underneath it?. It is essential IMHO to always have the laptop on a hard surface to allow maximum air flow.
    The new(er) Dell is better and that fan never runs (in fact I have never yet heard it!!)
  12. Photo4x4
    Photo4x4
    Jul 26, 2014
    371
    867
    Scottish Highlands
  13. Easyliving
    Easyliving Funster
    Dec 4, 2012
    686
    1,598
    Norfolk
    My desktop pc fan was very noisy right from day one. Looking on forums I found that if you go into your bios settings (press 'del' as computer fires up if I remember rightly) there is a setting there that allows you to vary the speed and therefore noise of the fan. Sorry this is so vague but I am at work at the moment so can't verify with my pc but I found the relevant setting okay.
    Paul
  14. keith
    keith Funster
    Aug 25, 2007
    3,301
    1,685
    Ecclefechan
    All seems to be running well now after a good blow out. I did also cleaned the system, via ASC, and a scan for viruses and malware.
  15. scotjimland
    Jul 25, 2007
    29,048
    25,741
    Suffolk
    This will be ok with a desk top.. they have plenty of cooling.. but
    I would caution against adjusting the fan speed in the bios settings in a laptop..
    it will reduce noise, but also reduce the cooling and consequently increase the processor core temperature...
    in my case, it is overheating, not noise that is the issue.. the fan in my Dell runs flat out and it still overheats after an hour or so of heavy use..
    My desk top PC fans seldom run.. and the 13" MacBook Pro never hear it .. and it runs as cool as a cucumber.
