KPH speedo swap (1 Viewer)
955matt
208
130
bexhill on sea
Hi I got a left hand drive burstner, with a KPH only speedo can I get an overlay or can I swap the speedo with a MPH speedo?
Many Thanks Matt
17,637
43,375
they make dual mph/kph overlay stickers cheap
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
every vehicle i have as kmh speedo. the tacho in my truck does show both but all my cars and m,bikes are in kmh . 100 km is 60mph near enough .
MattR
4,105
39,025
Beds
Panel van
Years
Many Thanks Matt
Yes you can - you may not need an overlay - it depends on what your speedo displays but you may need to get a device that intercepts the signal and changes the sensitivity of the dial so that it displays speed and distance in miles rather than km.
Something like this: http://www.charnet-ltd.com/KPH_MPH_Speedo.html
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Many Thanks Matt
Yes contact these
Steve N Tracy
1,235
3,728
Southampton
4 Years
Speedo converters like these will only work on vehicles with a AC or square wave digital signal Japanese vehicles, designed roughly before 2006 and European vehicles before 2000, you have not said what year your Burstner is but it probably has a CAN based vehicle wiring system these are mainly only available for Japanese domestic built vehicles as these are the most common imported vehicles that are converted, so the cheapest option would either be a overlay or a second hand speedo, if you go the replacement speedo route either S/H or new it will probably need to be programmed to the vehicle by a main dealer.
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Just use a sat nav like I do.
Mounted closer to eye level, rather than looking down into the gloom, it's much easier to read and more accurate.
Richard.
53,497
150,324
Richard.
It won't pass an inspection required by the VCA so you won't be able to get the VCA certificate you need to be able to register ghe vehicle.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Our current van and last van only had kph and both are uk registered and the older one passed MOT ok.
I suspect they were registered before the rules changed.
Mine was registered new in 2008 but since I acquired it I fitted an overlay. I don't understand why so many are resistant to this as it's easy and cheap.
Techno
Jul 28, 2010
15,475
20,756
May 2010
My original
My new one has Mph and kph
Techno
Jul 28, 2010
15,475
20,756
May 2010
Van built to order through UK dealer and registered by them.
If it's ordered to UK spec it should have mph & Kph same as a RHD
Mine was ordered to UK spec but it had LHD headlights KPH speedo and fog light wrong side. That's dealers for you
53,497
150,324
It will pass an MOT but you can not register a vehicle unless it has a mph speedo or duel marked speedo.
Quote from VCA form:
"That a speedometer has been fitted which is capable of indicating speed in both miles per hour and
kilometres per hour, either simultaneously, or by operation of a switch.
Note: We can not accept secondary devices, hand written changes or multiple stickers applied to the
speedometer. We can only accept the changes detailed below.
The speedometer must be marked up to the maximum speed of the vehicle, with graduations at 1, 2, 5, or
10mph, and with values at intervals not exceeding 20mph. For this change we can accept the following
options.
a) That the factory fitted speedometer is dual marked as standard
b) The existing (digital) speedometer is, permanently, re-programmed, through a standard feature of the
vehicle, to display the vehicle speed in mph
c) A miles per hour speedometer is fitted in-place of the factory fitted unit
d) A professional, single, miles per hour, overlay is applied directly to the speedometer face plate, not the
glass front plate (the overlay must be durable and accurate, with markings visible in both day and night
driving conditions).
e) A dual marked dial / facia has been added as a replacement to the factory fitted one"
Rules changed April 2012.
It would be more useful to the OP if people checked the rules before posting inaccurate facts.:)
Techno
Jul 28, 2010
15,475
20,756
May 2010
I have this one for sale £25 to anyone who wants it.
The speed scale must match and the warning symbols must match exactly as these all vary between models
955matt
955matt
208
130
bexhill on sea
Hi Guys thanks for the replys, The van is 2010 and has just passed the mot fine.
Techno i will check my display and let you know
Floydster
1,071
2,767
Where ever I lay my hat
A lifetime
Cheers for the heads up about this, didn't bother me as I always use a sat nav for speed as it's easier to see than the dashboard speedo. :)
Techno
Jul 28, 2010
15,475
20,756
May 2010
I much prefer to use the speedo especially abroad as there is a built in safety margin. If you use the sat nav which is bang on and you happen to be going just slightly over the speed limit you are caught guv
May 21, 2008
4,271
7,342
Oxford
WildAx Constellation
Since 2008
I believe my satnav (TomTom) is more accurate than my speedo. I have a Citroen Relay RHD, and I can't read the kph, it's too small, so use the satnav abroad...
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes it is as I said just before you so if it says 33 and you get flashed in equal to a 30 abroad you are too fast
With the speedo if it says 33 you are only doing 30 so a margin of safety.
I'm lead to believe they don't give you any tolerance so you'll get done
