Kampa Rally Air Awning attaching to my Motorhome (1 Viewer)
reynardracer
76
7
Twyford
A class Hymer
I'm a newbie
I have a Kampa Rally Air awning that attaches to the motorhome via either a 4 mm or 6 mm beading. The trouble is my awning is an Omnistor and the attachment is on the inside and therefore will not close properly when the awning is attached and it is also tad low.
My Hymer does have a channel that runs around the vehicle, like most caravans, but it is of a greater diameter than either of my beading attachments.
I am therefore looking for an alternative way of attaching the awning, either using the channel already on the motorhome, if I could find out the diameter of the channel and then get a joining piece made up or by using something else attached to the top of the current awning, don't want to drill holes in the motorhome.
Anyone had this issue and solved it.
Peter
kelv
672
895
leicester
Carthago 145
I have a omnistor awning with a kampa air awning it fits in the track have you any pics
sdc77
3,244
4,550
Weardale, Co Durham
There are two models of your awning... the XL or the L ... should git fine to an omnistore awning
Pics would help
R
reynardracer
76
7
Twyford
A class Hymer
I'm a newbie
The awning fits into the track ok, but the track is on the inside of the awning and hence with awning beading in the track it prevents the awning from closing. Sorry dont know how to add pictures on here! The awning is an XL used on my previous mh, but it works with this one also.
R
reynardracer
76
7
Twyford
A class Hymer
I'm a newbie
Thanks all for the replies. Once again a problem aired is a problem solved. Also found a rail from called a Thule Universal Tent Fixation which will do the job.
Kind regards for all the help
Peter
