Awning rail fitted for Kampa Rally Air Pro
Discussion in 'Motorhome Chat' started by scotjimland, Jul 28, 2016.
  1. scotjimland
    Jul 25, 2007
    28,940
    25,628
    I was unhappy with using the Omnister wind out awning to attach the Kampa Air Pro..
    several reasons..
    1. The awning walls didn't sit snuggly against the side of the van.. big gaps.
    2. It wasn't in the correct place to clear the hab door..
    3. Risk of damage to the wind out awning..
    I don't think it was designed to support a heavy porch awning.. someone on the forum (can't find the thread) reported they had broken their wind-out awning using it for this purpose..
    I bought the rail from JohnsCross and fitted today..
    It has an adhesive backing which makes it easy to fit.. it comes suppled with s/s self tapping screws and 2 drill bits.
    I measured down from the Omnistor 3/4 " and used a chalk line to mark the van.. stuck the rail on (3 pieces,) then drilled and fitted the self tapping screws.. the come suppled with tiny plastic washers.
    We were apprehensive that it may be difficult to feed the awning on, but it was easy.. I stood on steps and fed it on while Jan pulled from the other end with a cord I had attached..
    I am really pleased with it now.. it fits perfectly, close to van walls and the hab door now opens into the awning.. it clears the awning roof with ease..
    a few pictures..
    IMG_0981.jpg IMG_0982.jpg IMG_0983.jpg IMG_0985.jpg IMG_0984.jpg IMG_0986.jpg IMG_0987.jpg IMG_0988.jpg IMG_0989.jpg
    • Like it Like it x 9
    • Useful Useful x 2
    • Thanks Thanks x 1
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,968
    I fitted a similar rail to our Autoquest when we had a porch awning. It worked well apart from the fact that the wind tended to blow the kador strip along the channel, twisting the awning a bit. You might need to purchase a pair of awning end stops to prevent that. I'd send you mine but I can't remember where I put them :D
  3. Hymie
    Hymie Funster
    Nov 29, 2013
    594
    676
    Essex
    Hi Jim, is that the air pro 260?
    I am going to look at one today, but was wondering how to fit it.
    We have a 91 vintage Omnistor which I wouldn't want to fit an awning to and was looking at these rails yesterday.
    Is it a secure fix, I am a bit worried as the older Hymers have the mottled hammer type finish outer skin and am wondering if the screws provided give enough strength.
    Nice job by the way.
    TIA,
    Hymie
  4. golly
    golly Funster
    Aug 16, 2009
    1,191
    2,131
    Co Durham
    I was thinking of putting a rail on our new Van, how did you locate the support battens to screw into
  5. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,696
    3,218
    East london
    Great job..
    My only concern is it's strength.. You're happy so it must be good enough.
    Looks great though (we love our Kampa awning)
  6. Bellini
    Bellini Funster
    Sep 3, 2013
    757
    798
    Crowthorne, Berkshire
    I've had no problems, so far, attaching our Kampa Air Pro 390 XL to Udo's '92 vintage Omnistor.
    With the Omnistor wound out for eaae of attachment, we semi-inflate the awning to add some support and gently wind it fully back in.
    I do like your arrangement, Jim. Good job!
    • Like it Like it x 1
    • Thanks Thanks x 1
  7. Speve
    Speve Funster
    Jul 29, 2013
    2,191
    1,886
    Salisbury
    We have the air pro and found as Jim not happy fitting on Ormistor so I pop riveted awning rail to underside of Ormister casing that way I didn't need to drill bodywork of van it works well.(y)(y)(y)
    • Like it Like it x 2
    • Useful Useful x 1
  8. Ber090
    Ber090 Funster Life Member
    Dec 12, 2012
    502
    503
    N Yorks
    If Sikkaflex can hold my solar panels and sat dish I wonder if it would hold the awning rail. Anyone tried it?
    Cheers Bernie
  9. kelv
    kelv Funster Life Member
    Jun 23, 2014
    341
    274
    leicester
    I have the kampa air pro and you are right the air pro is heavy when winding the awning in.
    I am very careful and use a brush to take some of the weight but even so I still managed to damage the awing so putting a awing strip seems a good idea.
  10. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,742
    8,638
    Tropical Bar,Benidorm.
    We have an awning rail Sikkaflexed to our van. We have a Kampa Air Pro 390 XL which was attached to it for 4 months last winter in Spain. So far no problems.
    Brisey.
    • Like it Like it x 5
    • Useful Useful x 2
  11. Robin McHood
    Robin McHood Funster
    Mar 10, 2016
    249
    222
    Scottish Borders
    I bought the Kela drive away and have had it connected to our Omnistor ok, though ours is fitted so the porch fits over the door. Haven't had any problems so far and the porch is snug when wound back, though not as snug against the sides of the van as I'd like. Only other problem is that on CC sites it breaches the 6m rule which is a pain and something I should have thought of first!
    Like your installation though @scotjimland, very neat fit
    • Thanks Thanks x 1
  12. Ber090
    Dec 12, 2012
    502
    503
    N Yorks
    Hi Kelv, I think you could repair that damage with " Bondic" available on amaxon or fleabay. It is now my weapon of choice to repair everything . Expensive but works.
    Bernie
  13. Steve
    Steve Funster Life Member
    May 8, 2013
    1,589
    1,874
    Compton Berkshire
    yes, been on there for 18months still ok.
    • Thanks Thanks x 1
  14. kelv
    Jun 23, 2014
    341
    274
    leicester
    Thanks Bernie but I have already ordered a replacement end £19 + vat from leisure spares just hope it's the right one.
  15. busby
    busby Funster
    Aug 18, 2011
    3,645
    3,420
    derbys
    They are very small self tappers,,,they just screw through the skin. Awning rail is also self adhesive,,,,Did mine earlier this year,,works well. BUSBY...
    • Thanks Thanks x 1
  16. scotjimland
    Jul 25, 2007
    28,940
    25,628
    Yes.. the air pro 260 .. as other have said , with dimpled skin use Sikaflex and small self tappers
    as said .. not fixed to battons, just short self tappers and the adhesive on the rail .. for dimpled skin you would need to use Sikaflex
    yes. no problem.. but use self tappers to hold it in place while the Sika cures ..
    Thanks.
    the 6 meter rule is between vans.. as far as I know, it is 3 mts between awnings ..
    In Wales at present.. on a lovely CS .. called Cwmcuttan.. SA20 0LY www.cwmcuttan.com
    £12 per unit , no extra charges for dogs etc. .. 16A EHU and Free WIFI
    sorry for delay in replying ...
    • Thanks Thanks x 1
  17. walburga
    walburga Funster
    Aug 20, 2007
    300
    99
    Leyland
    Also got the 260 Kampa air pro, tried winding out the awning and fixing the kampa to that...hell of a struggle winding it back in ! In fact, couldn't get it to wind in fully, so we had a bit of a gap at the wall.
    I'd already thought of fixing an awning rail to the underside of the omnistor casing...so glad it's been done successfully by you.
    This is a job (one of many) that will wait till after our return from S of F late October.
    Allen
  18. Hymie
    Hymie Funster
    Nov 29, 2013
    594
    676
    Essex
    Thanks for the thorough reply, do you find the 260 big enough Jim?
    Was affected a new (ex display) air pro 200 yesterday for £125 but it feels a bit on the snug side.
    SWMBO is convinced we need a 390, not so sure myself but wondering, if you have 2 loungers and a table inside, is there enough room to access the hab door without weaving through an obstacle course?
    Sorry to pester you while you are chillin.
    Hymie
  19. Adbt
    Adbt Funster
    May 19, 2015
    596
    901
    Cheshire
    Really not sure I could be bothered with banging all those pegs in , especially into hard standing . What do you guys actually use those awnings for ?
  20. Hymie
    Hymie Funster
    Nov 29, 2013
    594
    676
    Essex
    We went to a site for the weekend, Fri eve until Sun lunchtime, brilliant sunny day Friday, woke Sat morning to clouds, strong chilly wind, the Mrs ended up wrapped in a Slanket after persevering with the cold Reece for several hours.
    With the awning up you can shelter from sun and wind or sit outside in the sunshine if you wish.
    The one we are buyin on Friday has 2 pegs on each side only and erects/dismantles in minutes.
    Hymie
